Question about Hotpoint Kitchen Ranges
Gas Hotpoint range says bad line. Is it safe to use for right now?? Is the gas bad or electric? I don't have money to fix it at the moment
    Top Expert:
  • Hotpoint Master
  • 40,775 Answers
If it is gas , then you have no option but to turn the gas off at the supply tap until you can afford a gas fitter to come and check the problem
if you continue to use it then the consequences could be you ceasing to exist form gas poisoning or an explosion
Posted on Dec 21, 2016
  • Amanda Lee
    Amanda Lee Dec 21, 2016
    I am asking if the error means gas or electric. Most everything I have found says that means an electric problem. I didn't smell any gas when it was showing the error
  • 7 Answers
SOURCE: Gas Range lighter continously triggers
check and clean the flame sensor
Posted on Jan 10, 2008
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
docjohn174
  • 943 Answers
SOURCE: GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Posted on Oct 14, 2008
  • 338 Answers
SOURCE: gas burner not igniting on Hotpoint RGB745, can smell gas
check to see if any of the port holes are clogged.. usually where the ignitor comes into the burner head
Posted on Jan 20, 2009
  • 116 Answers
SOURCE: Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Posted on Jun 06, 2009
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
My hotpoint gas stovetop is leaking aldehydes, per gas company. They said to replace gas burners. will this fix the problem?
I don't know your make and model number so can't tell you if it will or won't. BUT I would think the problem would be the gas valve and not the burners.
What led to the gas company being called? Gas odor? Give us some background to work with, so that we can give you better advice.
Jul 27, 2011 | Hotpoint Kitchen Ranges
I have a Hotpoint gas range that has electric ignition for the oven. However, I don't have electric at my cabin. Is there a conversion kit for a straight pilot ignition available? The model number is...
Most gas ranges with electronic ignition aren't equipped to have a straight pilot ignition.
I'm don't even think they make conversion kit because of the routing of the gas tubing for the pilot source.
Usually you have to turn the gas knob way over to get the "click-click-click" of the igniter.
Its just as easy to turn on the gas and light with a match...or a long butane lighter.
Even a "striker" used in welding will provide a source of ignition.
A last ditch effort would be to get a replacement gas grill igniter...all ya gotta do is place the bottom of igniter on metal surface and press red button. (kinda works like a spark plug) and no A/C needed.
Hope this helps some.
Jul 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Ignite pilot light on hotpoint gas range
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Hotpoint RGB745 Gas Kitchen Range
Gas oven Hotpoint RGA 720 I can't light the oven pilot
There is likely some kind of gas line blockage or valve problem. This is not a do-it-yourself fix. Call a repair person.
Oct 15, 2009 | General Electric Hotpoint® RGA720PKWH Gas...
How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Sep 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint range where the oven and clock display suddenly stopped working, but the gas range top does... what do I do?
Sounds like you have a bad main oven control board (ERC).
Bad new is you will need to replace it or have it replaced. Good news is that it is not difficult to do
Dec 20, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchen Ranges Logo
35 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
John Tripp
John Tripp
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
