Question about Samsung PN Televison & Video
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
I have opened the back and did not see any popped capacitors; five have a black dot looking like a dot was placed with a marker pen but the caps themselves are not bulging. There are five ceramic fuses, all of which tested fine with an ohmmeter allowing current to pass through.
    Master:
  • 507 Answers
The capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Posted on Jan 05, 2017
SOURCE: ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Posted on Nov 13, 2008
SOURCE: Samsung Plasma TV Model:HP-S5053
I had the same issues and the tech came out and replaced the main board... one way to tedt if it is the PDP is in the service menu.. run the plasam ttests and verify you don't see any dots. After replacement the tech checked all voltages and all is well.
Posted on Mar 28, 2009
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
sonicboomele
  • 1557 Answers
SOURCE: where can i find a ceramic fuse for my samsung
any tv repair company will gladley sell you one ever the counter if you have the blown one take it with you if not ask them to check the right values
hope helps
Posted on Apr 24, 2010
futurework
  • 70 Answers
SOURCE: insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
Posted on May 04, 2010
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Samsung plasma Model PN60E8000GFXZA not turning on just clicking, TV was on and we heard a loud pop, tv went to a black screen with no sound. when we turn on tv no picture, no sound, any suggestions
Plasma TV'S contain many capacitors and TV manufacturers us substandard quality capacitors to make these TV'S affordable to the general public. If one of these capacitors goes out the TV will no longer turn on. If you feel comfortable removing the panels from the TV you can look at the circuit boards and find the capacitor(s) that have went bad. They will either be burned or the top of them will be burst open or bulging. From your description you will probably have one that will be burst open. If you know how to solder electric components this is a very cheap and easy fix. A TV repair man will charge quite a bit to do this.
Oct 25, 2016 | Samsung PN60E8000GFXZA - PN60E8000 60 3D...
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung plasma tv does not turn on
Has anyone talked to you about bulging capacitors? Does it make any clicking noises? Does the power light come on? Have you opened the back of the TV?
Aug 18, 2014 | Samsung Televison & Video
Panasonic Plasma TV periodically will not turn on.
The power supply section of the tv may be faulty. Open your gadget and check if there are no popped up capacitors. When a capacitor at the power supply section is afftected by a surge, normally it pops up and resultantly affects the switching of the tv ....so check its voltage rating and capacitance and replace with the same value taking note of the polarity of the capacitor
Oct 04, 2017 | Panasonic TC-P46G25 Flat Screen Plasma...
My Philips 50PFP5332D 50 in makes this clicking sound when I try turning it on. The blue indicator light is on, but the tv won't turn on, it just continues to make this clicking sound for one hour or...
its the capacitor inside the tv open it up and you should see atleast 1 capacitor which has bulged ( looks like glue coming out of it ) usually a 3000 ~ you can replace these yourself no problem for around 10p each but i do warn you there is a chance you could lose your built in freeview in doing so!
Oct 29, 2011 | Philips 50PFP5332D 50 in. Plasma...
My Samsung 42" Plasma TV starting turning off in the middle of watching a program and continues to click trying to turn back on. Can you provide what needs to be done to fix the problem. Thanks Danny
check for bad connections leve it running and check what is heating up on the power supply look for bad capacitors try borrowing esr meter check all the capacitators
Sep 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
I have a sumsung 50'' plasma and it turns itself off after about five minutes then makes a clicking noise if i unplug it then plug it back in it stays on for the same amount of time then turns itself off...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 13, 2010 | Samsung PS50Q97HDX 50 in. Plasma TV
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
149 people viewed this question
Jerry Greenberg
Jerry Greenberg
