Monitor 441 only stays off for about 3 minutes before coming back on. Seems to run about all the time. Is this normal or is it coming on to often?
Thermostat set at 74 degrees. Heater goes off at 78-80 degrees. Takes 3 minutes for temperature to drop back to 74 degrees. Heater comes back on.
  • 1420 Answers
SOURCE: goodman gmp075-3
I am confident the technician(s) have done this but check anyway.
Gas pressure 4-7 inches W.C for natural, 10 - 11 for Propane.
Air filter clean and unrestricted.
Temperature over supply plenum 140 degrees F.
All registers open and unrestricted.
Vent and intake unrestricted and not blocked.
Condensate hoses free of debris and draining.
OK now lets check to see if the furnace is staying on long enough.When it runs for a heat cycle, is the flame staying on until about 2 minutes prior to achieving the set temperature or is it cycling everyfew seconds and never reaching temp? To check you will need to view the flame through a small viewing port of thru the fins in the front door. Watch them for 10 to 15 minutes.
If they are staying on a long time, we will need to see if the room blower is working properly. If they are going out quickly and or cycling. Get the technician on the pone to talk it over. It could be a safety sensor.
If the blower stays on and the burners are on as well, you have a door open somewhere. Just kidding. Remove the thermostst documenting which wires go where. Take the white wire and cross it with the red wire. This will (or should) turn on the furnace. Clamp them together untill the either the house gets warm or you are confident it is not going to reach temperature. If it did get close to the temperature you wanted, it is a thermostat issue. If not, you got me!
And they say we have an easy job! Get beck to us with your results.
Posted on Jan 23, 2008
  • 22 Answers
SOURCE: sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Posted on Dec 21, 2008
  • 979 Answers
SOURCE: preheat gets to temp but oven drops 20 d+/- after food goes in. Is this normal
You may have already solved this but either your convection motor is not on or you have an air leak. I would get the repair man out since it is probablt still under warranty.
Posted on Jan 14, 2009
  • 5158 Answers
SOURCE: 2000 Nissan Altima temperature gauge and heater problem
sounds like you need to replace the thermostat.
Posted on Jan 29, 2009
  • 4 Answers
SOURCE: Problem with No Heat on 2005 Chevy Avalanche - Cooling System?
it is most likey a sticking thermostat it either gets stuck closed or open in your case closed so collant isnt getting to the heater core and all you get is cold air blowing into the truck.
its a simple fix you can either do it your self or take it to a mechanic. now remember there are differnt thermostes so think about the climat you live in and get one according to that
The fan on the oven seems to run or a very long time after the selected program is turned off
I would call a dealer of the make and ask them if that is normal, sounds like perhaps it could be .
Feb 15, 2015 | Ovens
Po 171, po 305, po 441
Hi, I know from my past experiances the spark plug wires at the boot ends than slide onto the sparkplugs usually over time short out due to the metal tubes that protect the sparkplugs from heat kind of ark across from the metal tube through the plug boot causing an error code. Sometimes in the dark you can actually see them arking at the tube on the engine, and also hear a crackling noise. As to the code for the O2 sensor that's a normal wear and tear item that may need replaced. As all vehicle age over time electrical connections, and things have issues develop and cause havick with sensors and computers in these vehicles too.
As with the 441 code and then the other code for the O2 sensor showing up may mean both O2 sensors are going bad if your system has 2 sensors in the exhaust, usually one before the cat converter and one behind it. A lot of this also is due to what gasoline you use in the vehicle over time. Lower octane gas may be what is causing things to act up.
Jan 03, 2014 | Dodge Ram 1500 Cars & Trucks
I just purchased a new Frididaire side by side. I've had it 4 days. It runs about 13 minutes and is off about 11 minutes. Is this normal? Seems like it shouldn't run so much.
For a new fridge, need more time to maintain the required temperature of the fridge and mainly the goods in it? So everything seems normal. The time will be reduced day by day since the goods will stay for longer time in and door opening will become less and less.
So don't worry everything seems fine.
Oct 16, 2010 | Frigidaire Refrigerators
This monitor is great. Just recently, after 3
It seems so.
1. Change the monitor cable and see if this still happens
2. Attach this monitor to another PC and see if this still happens
If it is still happening, then yes, it seems that it is failing.
Mar 14, 2010 | Gateway FPD1760 17" LCD Monitor
My 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Jan 04, 2010 | Heating & Cooling
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Nov 30, 2006 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
