Question about Motorsports
I would love to know if anyone knows of a trophy top from the 50's called a Jalopy and resembles a '32 ford 5 window coupe. no fenders, square hole in roof and brass plated. I broke my dad's first 1.
    Top Expert:
  • 48,419 Answers
Call around the ford veteran and modified car clubs to see what information you can get
they are the most likely people that can help you
Posted on Dec 21, 2016
A lower ball joint was not installed properly caused me to wreck how much would it cost to fix?
Call a dealership for an estimate. It is not practical to guess without seeing it.
Feb 05, 2018 | Honda Cars & Trucks
Why can I hear the caller on my HTC Trophy on the Simple Mobile network?
sounds as if your phone is forwarding the calls to a computer, look into that and let me know,then we can go through the steps
Nov 22, 2014 | HTC 7 Trophy Cell Phone
Starter relay motor location
It's called an inhibit relay , an it is located in the battery junction or instrument panel fuse box.And it's controlled by the RAP module. remote anti-theft personality module. Do you know what a regular relay look's like one inch square little plastic box ? The solenoid is on the starter .
Sep 30, 2017 | 1997 Ford Escort
Oil to gas ratio for jonsered strimmer
Hi and welcome to FixYa, I am Kelly
It actually depends on the age of the unit. Anything within the last 5 years is 50 - 1. (Air quality standards!) Before that 40 - 1 and in the year 2000 it was 32 - 1.
Let me just say that running a unit with a 50 - 1 fuel mixture ratio leaves no room for error in the ability of the mixed oil to lubricate the engine and the engine piston will wear quicker than and engine with a higher ratio oil 32 -1. (Fact manufacturers don't want anyone to know!)
This on line calculator is great for computing mixtures with the exact quantities:
As far as what 2 cycle oil to use.... pick one. They ALL have to meet the same quality standards to even be called 2 cycle oil. Extensive testing has shown that no matter the mixture ratios form 32 - to 50 -1 they all eventually form carbon on the top of the piston. It was noted that carbon on the piston forms faster at 32 - 1 than it does at 50 - 1. (For what that is worth.)
Thanks for choosing FixYa,
Apr 23, 2011 | Garden
Belt tensioner is -placed were on a mercury topez 1988. i need to find it so ican put a new one one the car. i can not find it any were.
the front of hte engine faces the passenger side fender. The tensioner is an automatic tensioner. You put a 1/2 socket in the square hole to rotate it to relieve tension and take the belt off.
here's escort, tempo similar
Dec 14, 2009 | 1988 Mercury Topaz 2 Door
Does anyone know the fuel pump relay number in the fuse box for a 2001 explorer sport
The relay is under the hood in a fuse/relay box and should be labeled on the inside of the lid ....If i recall it on the pass side along the fender well
Nov 19, 2009 | 2003 Ford Explorer Sport
Crown Vic Fuel Line
I do not recommend doing this.
a 1/4 inch line has a .0491 square inch hole.
a 5/16 inch line has a .0767 square inch hole.
This would result in lowering the flow capacity of the line by over 30%.
You can possibly starve the engine of fuel causing the engine to run lean, which can result in overheating and even worse melting the tops of your pistons in the engine.
Most good automotive stores have many types of brake line and fuel line fittings and adapters you can purchase.
Good luck with your project!
Sep 09, 2009 | 1992 Ford Crown Victoria
1988 Ford Crown Vic Horn Relay Location
The horn relay IS NOT located in a box toward the front of the engine. It is located just behind the radiator overflow reservoir and attached to the inner fender next to two other relays. It is the only one without a plastic cover over the top of it. FYI, our Crown Vic horn didn't blow, and the cruise didn't work. I changed the relay and still no horn. I decided to check the horns themselves. Found wires disconnected from terminals. Touched wire to horn terminal and horn blew incessantly. (previous owner had disconnected horn rather than diagnose why) Pulled the horn "button" from steering wheel and disconnected the wire leads and horn quit. Disassembled the "button" assembly. Foam had degraded over time between the contacts. (Ford has discontinued this part). Cleaned and replaced foam with Scotch foam mounting squares with holes punched out over contacts (2 layers thick). Re-assembled and viola! Horn and cruise control both work! Relay was bad as was horn button.
Jun 27, 2009 | 1988 Ford Crown Victoria
How to change front driver side 2004 g35 coupe marker light
Just pop out the side marker from where the marker meets the fender well and push outward on the side marker. It has a metal clip retaining it to the bumper.
This entry was in January, most likely you figured it out already.
Jan 19, 2009 | 2004 Infiniti G35 Sport Coupe
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Dec 01, 2008 | Texas Instruments TI-30XA Calculator
Motorsports Logo
373 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Steve P
Steve P
Are you a Motorsport Expert? Answer questions, earn points and help others
