Question about Microsoft Office Professional 2007 Full Version for PC
MS Word Shuts down
During transcription typing, word shuts down and asks for the completion of a general problem summary. Nothing is ever fixed. This is a real problem because I am running a business from home. Time is money and I can't afford to be shut down. This happens quite a few times per day. Please help.
    President:
  • 828 Answers
Reinstall your Microsoft Office to another directory, not a default one. and if your system is updating, turn-off on it. it might be the reason why your Office is crashed.
Posted on Jul 21, 2009
We got the keyboard on to the iPad but nothing is happening can’t type
I have an older iPad2, and had a similar issue.
My fix for my iPad was:
I reset the system: Simultaneously hold down the "Home" and "On" buttons until the iPad shuts down.
(Ignore the off slider if it appears).
Once shut down is complete, if it doesn't restart on it own, turn the iPad back on using the On button.
I've had to do this twice in as many years.
Dec 19, 2017 | The Computers & Internet
My phone Huawei U9200 shuts down completely during booting,i hard reset it but no joy either.
You have to fear it is defect. Visit a phone store and ask them. If it is under waranty bring it back. I hope you did make backups.
Apr 18, 2015 | Cell Phones
When I play Candy Crush my computer shuts down.
Possible solution, uninstall completely, reboot, making sure it's not hardware and reinstall, being sure not to install any other options during installation, sometimes they bundle other stuff, read carefully. See if that works.
Jan 03, 2015 | Candy Video Game Consoles & Games
Apps unresponsive kyocera hydro
Try performing a Factory reset on the phone. This will generally fix bugs related to auto shut downs.
Aug 15, 2014 | Boost Mobile Kyocera Hydro Smartphone
Computer shuts down even during operation system install
It seems pretty deffenant the over heat problem was not fixxed very well. Demand they stand behind their work & fix it again.
Jul 13, 2013 | Toshiba Satellite L500 Series Notebook
I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
Dear Sir:
I hope your are very well in union with your family.
I will help you inmediatel.
Please do the following:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
1)
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker.
The amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
2)
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
3)
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact us with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing.
Thank you in advance, sincerely. God bless you.
If you need further assistance,please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Exercise & Fitness
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
PC shuts down after logging in to WinXP pro Athlon uP
reinstall the window xp
open my computer from the start manue
go to view and open folder options
show the hidden files and also deselect the protecting window files below it
and apply
then click on the folder on the top in the my computer
and remove all the suspected hidden files from all the drives and restart your system
Dec 21, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Ms word shuts down each time I try to use it
Make sure that the ser's temporary folder is completely empty or close all the applications and empty the temporary folder.
Usually this temp files cause the shut down of the office program.
Then, run the office repair tool.
This will resolve the issue.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
