Have a monitor 441. From the time it reaches desired temp and temp starts to drop it is about 3 minutes and the heater starts again. Heater almost runs all the time. Is this normal?
bbtoast
  • 319 Answers
SOURCE: shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
Have you looked at, and or followed the troubleshooting suggestions at this website?
There is a full troubleshooting guide for your model. Let me know if you have checked this site out, then give me more details as to any other indications.
How old is this unit, how long has it been plugged in to the current electric outlet, etc.
Thanks
Brian
Posted on Jan 19, 2008
  • 366 Answers
SOURCE: 2004 Tahoe Heater Problem
check coolant level ,must be low ,chck for coolant loss
Posted on Mar 05, 2009
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
paulm10
  • 73 Answers
SOURCE: AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
Posted on Jul 13, 2009
  • 21 Answers
SOURCE: Goodman Heater kicks on but then it goes off as
the gas furnace has a flame sensor when the flame kicks on and the flame sensor doesn't sense it it will shut off as a safety precaution and try three times to start again and then will lockout what you need to do is find the flame sensor it usually looks like a metal rod about 1'' -1 1/2'' long in a porcelain cylinder. it looks kind of like a mini screwdriver. You have to clean the metal rod with sandpaper or sandcloth the flame sensor actually conducts electricity with a flame cleaning them usually works make sure you check your connections especially ground.
Posted on Oct 30, 2009
How do I fix the heater? The igniter will not stay on long. The heater never reaches desired temperature.
Try turning it off and unplugging it for 30 seconds. If that doesnt work, some people I know had to melt ice from their vents with a blow dryer. If not call a technician. Error codes should be in the manual. http://www.rinnai.us/customer-care/manuals-literature
Feb 24, 2015 | Rinnai Toyostove Direct Vent Heater: Laser...
Manual Hph15led
1. Plug unit in
2. Press Power button once - small dot appears on LED screen
3. Adjust desired temp with + / - buttons
4. Press Power button again to set time
5. Adjust desired time with + / - buttons
6. Adjust power output level with Mode button
Has anyone had the probelm with this heater (HPH15LED) that it doesn't continually turn back on to maintain a constant temp? I find it reaches the set temp and then doesn't come back on??
May 02, 2013 | Heating & Cooling
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
My 441 monitor heater will ignite and then it burns for a little while then goes out and starts flashing.
sounds like your heater may be starving for fuel. check all your rubber hoses for cracks first and then continue troubleshooting from there.
Nov 27, 2010 | Reddy Kerosene Heater with Thermostat:...
My friend has a monitor mpi 441 heater,mounted on top theres a thermo disc about the sizeof a dime with 2 wires going to it.i ohmed it out,it had no continuity,i gumped it out it started.I have a universal...
Hello.If there are any numbers on the old part ,that will tell you the temp it was set at.other wise start at a lowest temp on the universall to be safe,
Oct 26, 2010 | Heating & Cooling
Wall Heater
If you have already changed out the thermocouple and the pilot goes out when the burner goes out, it leads to reason that the gas valve has a weak magnet or that the pilot is dirty. The cheapest thing would be to remove the pilot assembly and clean out the orifice. If it still drops out, you will need to replace the gas valve.
Nov 02, 2009 | Heating & Cooling
Heater does not come back on
I found that if I unplug the heater from the power outlet for about 3 to 5 minutes, it goes back to normal. Ive had my heater about 1 year, and have successfully done this twice. Hope this helps~!
Dec 17, 2008 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
