Question about Rand Mcnally GPS
I need to talk to same at rand McNally about get a new face cover for a 720b gps
GeOrGeEtUk
  • 332 Answers
SOURCE: Why will Vista not run Rand-McNally Trip Maker?
Check the system requirements to know if it meets the requirements.
Regards
Posted on Aug 29, 2009
SOURCE: Rand McNally TND 500 displays
I suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Aug 22, 2010
mc1bean
  • 3053 Answers
SOURCE: Droped my new rand mcnally gps and cracked the
You can replace a cracked GPS screen, but you can't repair it. If your GPS is under warranty, you can contact the manufacturer directly about sending the unit back to have the screen replaced. If the device is not under warranty, you can still contact the manufacturer about replacing the screen. The company will charge a fee to replace your GPS screen if you don't have a warranty that covers that type of repair. You can also replace the GPS screen yourself, but be aware that replacing your GPS screen can void your warranty.
Instructions Things You'll Need
  • Mini Philips screwdriver
  • Flat-head screwdriver or other pry tool
    • 1 Purchase a new GPS LCD screen. There are many sources online that sell GPS screens (see Resources). Look for compatible unit information next to each replacement screen online before purchasing it to make sure it matches your GPS model.
    • 2 Power off the GPS and remove any peripheral cables from the device.
    • 3 Remove the screws from the cover. The number of screws varies depending on the GPS; there may be two to four screws located on the bottom or rear of the GPS. You will need a mini Philips screwdriver (like those found in computer repair kits) to loosen the screws.
    • 4 Remove any further screws holding down the internal antenna.
    • 5 Wedge a flat-head screwdriver or another pry tool in between the front and back case of the GPS. Use the pry tool to pull the front and back cover apart. Once open, you may notice that the back cover contains a battery or other component, and the front cover houses the motherboard which is over the screen.
    • 6 Touch a piece of metal, such as a metal tool or metal door knob, with your hand to demagnetize yourself. This prevents the motherboard from being destroyed by any static electricity in your body.
    • 7 Remove any screws holding the motherboard to the front of the case. Then move the motherboard out of the way when it is loose enough. The motherboard will still have wires connected to different components that are embedded in the front of the GPS case.
    • 8 Disengage any wires that are connecting the motherboard to the front case components such as the SD card or phono/audio jack. There is typically a lever that must be pushed to disengage these wires.
    • 9 Pull the screen's ribbon cable connection from the motherboard. Be careful, the ribbon cable is delicate. Discard the old, cracked screen. You can now insert your new screen into the front cover of the GPS. Reconnect all of the ribbon cables and wires that you disconnected to remove the motherboard, and close the GPS case back with the required screws.
    HERE IS THE LINK BELOW TO COPY AND PASTE AND PUT IN YOUR BROWSER AND THIS IS YOUR OPTIONS, CAN CONTACT THEM AND SEND IT IN AND THEY CAN REPLACE IT FOR YOU, OR CONTACT THEM AND HAVE THEM SEND YOU OUT THE PART AND REPLACE YOURSELF, BASED ON INSTRUCTIONS I LISTED ABOVE.
http://store.randmcnally.com/?SCCampaign=cjaff&gclid=CPe2iu2B36oCFVAaQgodIwM58g
MY ADVICE IS : Sense your unit is expensive and new, it is worth having them fix it or fix yourself. I hope hope this helped you, and on the good size you for sure have a good unit. Thanks Mike , your fixya Expert.
Posted on Aug 20, 2011
  • 4 Answers
SOURCE: i need instruction manual for navigator rand mcnally gps receiver
Would this be it?
http://content.etilize.com/User-Manual/1010509357.pdf
Posted on Feb 20, 2012
Testimonial: "many thanks for your help"
emissionwiz
  • 76848 Answers
SOURCE: rand mcnally tnd 710 not turn on
If it is more than a few years old then the battery is a real possibility as the problem.
Posted on Apr 20, 2012
How do I get the new map updates
Simply plug your gps into any internet ready computer and go to the link below. Follow the instructions on screen.
https://randmcnally.yonyx.com/y/conversation/?id=b1885070-a58d-11e4-a2c4-bc764e11861e
Note;
You will need to download software for this which can be found at
Rand McNally Dock
Feb 11, 2016 | Rand Mcnally intelliroute TND 720 7" GPS...
I need download on my gps rand McNally so how I can do ?
This question, along with many others is answered in the support section on www.randmcnally.com.
The direct link is - http://www.randmcnally.com/support/faqs/updating-gps-software
All updates are completed using the Rand McNally Dock. The Rand McNally Dock is a software application you download and install on your PC/Mac. The software is free and can be found, along with instructions at - http://www.randmcnally.com/support/s/dock-software
For a step by step tutorial on updating your device you can review - https://randmcnally.yonyx.com/y/conversation/?id=b1885070-a58d-11e4-a2c4-bc764e11861e.
Please call technical support if you require additional assistance.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
Mar 19, 2015 | Rand Mcnally GPS
How to update my tnd intelliroute 510
All updates are completed using the Rand McNally Dock. The Rand McNally Dock is a software application you download and install on your PC/Mac. The software is free and can be found, along with instructions, at www.randmcnally.com/dock.
For a step by step tutorial please visit - http://www.randmcnally.com/support/faqs/updating-gps-software
Jun 23, 2014 | Navigator Rand McNally GPS GPS Receiver
I cannot find howtoo update my Randmcnally 7710.
Go to Rand Mcnally dock window;
Click to update your TripMaker RVND software
You can get the pdf file here http://www.randmcnally.com/images/randDocuments/support/RVND_User_Guide_v104.pdf
Apr 19, 2014 | Rand Mcnally TND 710 GPS Receiver
INSTRUCTION FOR UPDATE
Apr 16, 2014 | Rand Mcnally Intelliroute TND-520 LM Truck...
Not talking
Well not sure that you posted this in the right section. If you are talking about a Rand Mcnally TND 710, then yes it won't give you text to speeech, that feature is not in the 710 the 720 or even the 510 or 520.
Sep 06, 2013 | Rand Mcnally TND 710 GPS Receiver
How do i take off the message application herems2.exe encounter a serious error and must shut down on TND 500 Rand mcNally
Rand is working on this. A new version may be available soon that addresses this issue.
Thanks,
Mark
Oct 24, 2010 | Rand Mcnally TND 500 Car GPS Receiver
My new tdn 500 does not turn on and it is fully charged?it does not even communicate with the computer.what do i do?
Try pressing the reset button on the side or the back, If it still does not turn on contact Rand McNally support and have the serial number ready, (back side, bottom right).
Thanks, mark
Rand Lead Beta Tester
Aug 10, 2010 | Rand Mcnally TND 500 Car GPS Receiver
Need truck routes
If you need truck routes by the Rand Mcnally truckers map book, or for gps Pc Miler gps or Rand MCNally truckers gps, these are truck specific and will keep you on the truck route, if you are looking for it for your explorist, then you are out of luck. Sorry
Mar 12, 2010 | Magellan eXplorist 400 GPS Receiver
GPS Logo
23 people viewed this question
Top Rand Mcnally GPS Experts
Michael Vincent Cruz
ray gallant
Are you a Rand Mcnally GPS Expert? Answer questions, earn points and help others
