Hi
Intake/Drain light flashing means an issue while
draining. You would need to check for air gap on the dishwasher, it may be
clogged. It prevents dishwasher from draining, sometimes the drain flow is
restricted due to gunk. Cleaning or bypassing the air gap will resolve the
issue. If this doesn't resolve the issue then it is due to seized (or stuck)
drain pump. Disconnect the power to the dishwasher or turn off the breaker to
the dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections &
remove motor (single screw holds motor, it is on the outside back of the
machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate
it, then motor will be required. If the error still appears then cancel the
error message, turn the rotary selector switch to "Stop/End" or press
the "Start/Stop" switch for approx. 5 secs. Switch the appliance off
and then back on again. Hope this helps... Please post back if you need more
information.
Daniel
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
