Question about Kitchen Ranges
I had a consol stove but now i switch to an indurama stove so am not sure wat degrees to put the oven on seeing that it does not have a 350 degrees marking.
  • 1,934 Answers
Do you mean the old one was marked in Fahrenheit and the new one in Celcius degrees?
If so, 350 deg F is 175 deg C.
If you need a conversion chart see here
https://cdn.swifttips.com/samples/Temperatures.png
Posted on Dec 22, 2016
    Top Expert:
  • Kitchen Ranges Master
  • 52,166 Answers
Read the manual
Posted on Dec 21, 2016
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
  • 131 Answers
SOURCE: Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Posted on Mar 10, 2008
freetek
  • 5568 Answers
SOURCE: Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Posted on Nov 27, 2008
crayzeetrayn
  • 837 Answers
SOURCE: temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Posted on Feb 08, 2009
  • 67 Answers
SOURCE: Hi, I just purchased a second hand Frigidaire
the previous owner was on lp gas, you are on natural gas. the orfice ratings are different. call a professional to convert the range back to natural gas.
Posted on Sep 29, 2009
How do I keep the flame alight in my Indurama. Monte carol model stove. It keeps going out after half an hour of baking
Somethin in the control or gasvalve. Unplug system to see if reboot ir search utube...great repair
Dec 25, 2015 | Kitchen Ranges
Kenmore electric range mod.750.9210,9220,9230,9240 Oven does not come on
Check fuses first. If OK, Unplug from wall, unscrew the bracket that attaches the lower bake element to the wall of the stove..(usually held to wall by a few small screws). Clip VOM test meter leads to the two terminals. Set meter to at least 250V AC. Make sure test leads and screws do not touch any metal anywhere. Best is to put a piece of plastic or cardboard under the test leads to isolate the leads from the bottom of the oven. Once connected and properly isolated, plug stove in, turn stove on to bake 350 degrees and look at the voltage reading. If 250V is there element is bad. If no voltage switch or wiring between switch and element is bad.
Aug 08, 2014 | Kitchen Ranges
Kenmore Gas Stove, Model No. 790.72404013, oven signals it has preheated to 350 degrees in 7 minutes but it is nowhere near 350 degrees when it does this. Seems to take approximately 20 minutes to reach...
Sorry to read about your problem, I hope this helps you out.
ok it seems you have a offset issue, you need to purchase a oven temp gauge. See what the unit read's, lets say you set the oven for 350, does it read 320 or 380. 20 min for 350 is little on the long side, you may have a gas pressure issue.
I would get a 2nd opinion on this matter. and no, they are not all like that.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Kenmore Kitchen Ranges
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
KGST307 gas stove has a temperature control problem.
the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
