Question about Rand Mcnally GPS
I broke the face on my 720 rand mcnally how do I get a new one for it
GeOrGeEtUk
  • 332 Answers
SOURCE: Why will Vista not run Rand-McNally Trip Maker?
Check the system requirements to know if it meets the requirements.
Regards
Posted on Aug 29, 2009
SOURCE: Rand McNally TND 500 displays
I suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Aug 22, 2010
  • 2340 Answers
SOURCE: How to install RAND MCNALLY
Using free software to image & run image on Virtual Drive.
By creating an image file of your CD to a location on your PC/Laptop, using IMGBurn from http://www.imgburn.com/
Installing & Using a virtual drive eg MagicISO Virtual CD/DVD-ROM from http://www.magiciso.com/tutorials/miso-magicdisc-overview.htm
Tutorials :1. Using MagicDisc to mount CD/DVD image
2. Using MagicDisc to unmount CD/DVD image
Hope it helps.
Posted on Mar 13, 2011
mc1bean
  • 3053 Answers
SOURCE: Droped my new rand mcnally gps and cracked the
You can replace a cracked GPS screen, but you can't repair it. If your GPS is under warranty, you can contact the manufacturer directly about sending the unit back to have the screen replaced. If the device is not under warranty, you can still contact the manufacturer about replacing the screen. The company will charge a fee to replace your GPS screen if you don't have a warranty that covers that type of repair. You can also replace the GPS screen yourself, but be aware that replacing your GPS screen can void your warranty.
Instructions Things You'll Need
  • Mini Philips screwdriver
  • Flat-head screwdriver or other pry tool
    • 1 Purchase a new GPS LCD screen. There are many sources online that sell GPS screens (see Resources). Look for compatible unit information next to each replacement screen online before purchasing it to make sure it matches your GPS model.
    • 2 Power off the GPS and remove any peripheral cables from the device.
    • 3 Remove the screws from the cover. The number of screws varies depending on the GPS; there may be two to four screws located on the bottom or rear of the GPS. You will need a mini Philips screwdriver (like those found in computer repair kits) to loosen the screws.
    • 4 Remove any further screws holding down the internal antenna.
    • 5 Wedge a flat-head screwdriver or another pry tool in between the front and back case of the GPS. Use the pry tool to pull the front and back cover apart. Once open, you may notice that the back cover contains a battery or other component, and the front cover houses the motherboard which is over the screen.
    • 6 Touch a piece of metal, such as a metal tool or metal door knob, with your hand to demagnetize yourself. This prevents the motherboard from being destroyed by any static electricity in your body.
    • 7 Remove any screws holding the motherboard to the front of the case. Then move the motherboard out of the way when it is loose enough. The motherboard will still have wires connected to different components that are embedded in the front of the GPS case.
    • 8 Disengage any wires that are connecting the motherboard to the front case components such as the SD card or phono/audio jack. There is typically a lever that must be pushed to disengage these wires.
    • 9 Pull the screen's ribbon cable connection from the motherboard. Be careful, the ribbon cable is delicate. Discard the old, cracked screen. You can now insert your new screen into the front cover of the GPS. Reconnect all of the ribbon cables and wires that you disconnected to remove the motherboard, and close the GPS case back with the required screws.
    HERE IS THE LINK BELOW TO COPY AND PASTE AND PUT IN YOUR BROWSER AND THIS IS YOUR OPTIONS, CAN CONTACT THEM AND SEND IT IN AND THEY CAN REPLACE IT FOR YOU, OR CONTACT THEM AND HAVE THEM SEND YOU OUT THE PART AND REPLACE YOURSELF, BASED ON INSTRUCTIONS I LISTED ABOVE.
http://store.randmcnally.com/?SCCampaign=cjaff&gclid=CPe2iu2B36oCFVAaQgodIwM58g
MY ADVICE IS : Sense your unit is expensive and new, it is worth having them fix it or fix yourself. I hope hope this helped you, and on the good size you for sure have a good unit. Thanks Mike , your fixya Expert.
Posted on Aug 20, 2011
  • 4 Answers
SOURCE: i need instruction manual for navigator rand mcnally gps receiver
Would this be it?
http://content.etilize.com/User-Manual/1010509357.pdf
Posted on Feb 20, 2012
Testimonial: "many thanks for your help"
Missing system file message
We are going to need to know when the message appears and what operating system you have. If you have your system disks and if you installed or removed any programs.
Apr 02, 2016 | RAND Mcnally Intelliroute TND 720 Wifi...
How do I get the new map updates
Simply plug your gps into any internet ready computer and go to the link below. Follow the instructions on screen.
https://randmcnally.yonyx.com/y/conversation/?id=b1885070-a58d-11e4-a2c4-bc764e11861e
Note;
You will need to download software for this which can be found at
Rand McNally Dock
Feb 11, 2016 | Rand Mcnally intelliroute TND 720 7" GPS...
How do you change the time on the new rand mcnally tnd tablet to daylight savings time
To ensure the correct time is on your tablet to to the settings menu. Then select Date & Time. Check the boxes for Automatic date & time and Automatic Time Zone.
Please contact Rand McNally support if you require additional assistance.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
Mar 09, 2015 | Rand Mcnally GPS
My rand mcnally 720 tnd said files missing now after connecting to pc its froze at connected
The answer to this question and many others can be found in the FAQ section on our support page at www.randmcnally.com/support. Additionally, for instructional videos on many of the TND & RVND features please visit the Rand McNally You Tube page at www.youtube.com/randmcnallyonline.
To correct the issue please perform a Diagnostics & Repair using the Rand McNally Dock. Step by step instructions can be found at - http://www.randmcnally.com/support/s/diagnose-and-repair
If the Rand McNally Dock does not find an issue with any files, the repair fails, or the Diagnostics & Repair does resolve your issue, please call technical support for additional assistance.
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
TNDSupport@RandMcNally.com
Aug 31, 2014 | Rand Mcnally IntelliRoute TND 720 GPS...
Cracked screen
contact manufacturer to see if they can replace LCD or try to find faulty one with good LCD and relace it yourself
Mar 31, 2014 | Rand Mcnally IntelliRoute TND 720 GPS...
Not talking
Well not sure that you posted this in the right section. If you are talking about a Rand Mcnally TND 710, then yes it won't give you text to speeech, that feature is not in the 710 the 720 or even the 510 or 520.
Sep 06, 2013 | Rand Mcnally TND 710 GPS Receiver
Intelliroute 720 will not charge
any one know why when u update the device it want charge!!!!
Feb 02, 2013 | Rand Mcnally IntelliRoute TND 720 GPS...
How do i take off the message application herems2.exe encounter a serious error and must shut down on TND 500 Rand mcNally
Rand is working on this. A new version may be available soon that addresses this issue.
Thanks,
Mark
Oct 24, 2010 | Rand Mcnally TND 500 Car GPS Receiver
GPS Logo
Top Rand Mcnally GPS Experts
Michael Vincent Cruz
ray gallant
Are you a Rand Mcnally GPS Expert? Answer questions, earn points and help others
