Question about Cooking
How do i get my top o matic poweroll to fill the tubes completely? There is very little tobacco at the end by the filter.
2 Suggested Answers
denmason
  • 6 Answers
SOURCE: top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Make sure that your tobacco is not too wet. Set some tobacco out (about the amount you plan to roll) and let it air dry for about 5 - 15 minutes. You'll have to figure out how long to let it dry as your home temperature is different than mine. Don't let it dry too much though. Give this a try. It works for me.
Take care,
Dennis Mason
Posted on Jul 24, 2009
My crank wont move
are you loading it too tightly? w/o tobacco will it move? Take the rubber bottom off and inspect a touch of oil on rubbing parts
Jan 19, 2016 | Top-O-Matic Topomatic Cigarette Rolling...
Why cant i get a decent cigarette out of my powermate II mach.
I am going to go under the assumption you are using 100mm tubes. I just switched to kings to make life easier but here is how I filled my 100mm to the filter with good compaction and a trick to get it to the filter. I tightly pack the tobacco against the left side, sticking my finger in the chamber and pushing pretty hard to compact to the left side, I then just do a light poke for the rest of the compartment. Here is the trick part, take a finger and put light pressure pushing on the filter towards the machine, but not so hard it bends the tube and also no so hard that when the injector probe comes out it pushes your finger away from the machine. Using this method I would get around 9 good packs with one redo out of 10 injections. The key is to have enough pressure to hold the filter at the point where the plastic tab usually pushes out and then let the probe push your finger away from the machine. Only very light pressure is needed to make the difference. If the cigarettes are not packing tight you are not compacting enough tobacco in the chamber. There is a fine line though, you need to find the balance as stuffing too much in will cause it to bind up, you just need to find the balance. Once you figure it out it will go very quick, I stuff mine while on the phone and can do around a pack every 2 to 3 minutes or so and get a cigarette that can not be distinguished from a store bought one.
Another tip: I use old cigarette packs as containers for my DIY smokes, you can do the same here with a plastic case. If I do get some that are not fully pushed against the filter using the above method, or if the pack just seems a little loos I put them aside and at the end I load them all in cigarette packs just like they come from the store, filter up (otherwise I have a habit of smoking filters from years of them being positioned this way!) and once the pack is full (add good ones if there is space for them to move around, it will not hurt them) turn the pack upside down so the lid is on the bottom. Now tap them firmly about 10 to 20 times against a hard flat surface. This will move the tobacco towards the filter if there is a space or pack loose cigarettes.
Warning: From my experience :) Do not over stuff the machine or using the compacting method do not over pack the tobacco, find a good medium. If you over pack the smokes will be solid and very hard to drag from. Do not smoke cigarettes that are hard to rag from, the extra force needed by your lungs followed by introducing smoke into your lungs will result in pain and maybe worse, but I only made that mistake once.
Jan 07, 2016 | Powermatic 2 Electric Cigarette Injector...
Tube does not fill down by filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine.
Apr 08, 2014 | Powermatic 2 Electric Cigarette Injector...
Machine only rolls half cigarettes
Try cleaning it with alcohol first. Your question is vague so im
nit sure where the problem is.
But it won't hurt to clean it first !
Apr 06, 2014 | Top-O-Matic Topomatic Cigarette Rolling...
The handle sticks when crank to push tobacco throuh
Clean it with alcohol. Wipe it down , it removes tar and sticky residue without getting it soaking wet. Alcohol works great on ashtrays also !
Mar 24, 2014 | Top-O-Matic Topomatic Cigarette Rolling...
Tube will not fill near filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine...
Jan 15, 2014 | Powermatic 2 Electric Cigarette Injector...
Tobacco doesn't go to the end of the tube
Nov 12, 2013 | Powermatic 2 Electric Cigarette Injector...
Top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Take care,
Dennis Mason
Jun 17, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Cooking Logo
688 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
