Question about Craftsman Garden
While mowing with a brand new craftsman riding mower it sounded like it hit maybe a small rock and quit running. When you go to restart it just has a clicking sound
  • itsman Dec 21, 2016
    Crazy phone pto is on if it's one click when you turn key
  • 89 Answers
If it clicks once each time you the the to start my guess would be pro is on
Posted on Dec 21, 2016
  • Craftsman Master
  • 21,006 Answers
That sounds like a flat battery, faulty starter solenoid or starter. Hitting a rock would be coincidental to bad starting unless the stone kicked up and damaged a cable, but that should be impossible.
I have a brand new craftsman 32 " riding mower my daughter was moving it and driving too fast and hit a metal stake in ground and it died and now key won't turn over and it won't start could she have...
May have sheave timing key. It hold the flywheel in time. Pull shroud, remove big nut, remove flywheel, replace key in flywheel and crankshaft. 2 dollars for key.
Mar 27, 2015 | Craftsman Garden
17hp briggs and stratton shut down while mowing and won't restart. gas in tank is bubbling
Sounds like a blown motor but maybe not.I can take a look at it ifr you like/
Apr 14, 2013 | Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My wife was mowing the lawn and she hit a rock. Since than the lawn mower does not start and when it tries to start a little smoke will come out of the carburator area. The mower is a Sears eager 1...
Unless the blade is belt-driven, like on riding mowers, then the blade is attached directly to the engine crankshaft. Hitting a rock with a mower like this is a very common problem. You probably have a bent crankshaft. In most cases this can be repaired, but may not be worth it, considering the age of the mower. But you should call a local small engine/mower repair shop to ask for an estimate. The repair is not something you would be able to do yourself.
Apr 30, 2010 | Craftsman Garden
The last time I used the mower, it was running fine then cut off while I was mowing. I haven't been able to get it restarted. I changed the spark plug, filled the gas tank and added oil. It still will not...
Maybe the ignition module is gone bad. It helps fire the spark plug to make the motor to run. Also if it has a stop cable on it make sure the cable pulls back far enough to pull the flywheel brake off the flywheel.
If your mower was running then quit, it sounds like the ignition module bad.
Sep 27, 2009 | Craftsman Garden
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Brand new Craftsman 19.5 HP Riding Mower Sputtering(Manual Trans)
The hose you reconnected was probably for the air to the air filter. Check to see if while the hose was disconnected it pulled grass or dust into the air filter. Check the air filter, try running the mower without the filter. If it runs then replace or blow out the air filter. Hope this helps.
Jun 23, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
