Question about Samsung Refrigerators
How to get old dried ice out of the container in the side by side Samsung fridge as it will not come out on the door
  • Samsung Master
  • 5,323 Answers
Tyr using a blow dryer for several minutes
Posted on Dec 27, 2016
Have a Samsung French door fridge. Emptied the ice container in freezer and has t made ice since.
check the arm that it is not locked in the upper limit and therefore will not make ice .
Mar 10, 2018 | Samsung Refrigerators
Should I buy a Samsung 26 cu. ft. french door fridge with ice maker on top?
hey there, it depends on your budget and what fits in your kitchen, my self have a
Samsung RFG23UERS1 fridge and i am very happy with that one, so like i said its up to your budget and if it fits
Nov 25, 2013 | Refrigerators
Ice maker does not work.
Make sure the wire lever is pushed down calling for ice.Otherwise the unit thinks its full.
Jan 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Apr 21, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
