Question about Panasonic Televison & Video
Does Panasonic have a life time guaranty on their television sets
    Problem Solver:
  • 18 Answers
No. Are you kidding
Posted on Dec 23, 2016
    Top Expert:
  • Panasonic Master
  • 48,349 Answers
noe electronics have a lifetime guarantee
normally it is 2 - 3 years with an extended warranty for 3 years that you pay for
Posted on Dec 21, 2016
Panasonic TV slow to turn on, works fine after it turns on.
If you have to try to turn it on several times it is power supply related.
If dirty inside on fans etc it would cause set to shut down(the set monitors the fans for speed)>
I would suggest (take it outside) using a air compressor and cleaning the entire set out.
Lamps do fail---average life is 2000 hours for a original lamp and much less for a generic one.
If picture comes up try to watch the light from the lamp---if dim at first and then slowly comes up---it could be the lamp or the ballast the set uses to power the lamp.
Jun 10, 2012 | Panasonic Televison & Video
No screen and clicking sound
This set and the one before it (50lc13) had so many problems the latter was recalled and all were exchanged.
Someone would have to open set and check power supply first--set is not real easy to work on.
The recall involved issues where the sets were eating lamps up alive--very short lamp life---solution at first was to rebuild/replace the Ballast which drives the lamp.
Average life should be 2 years or 2,000 hours on that lamp.
May 25, 2012 | Panasonic PT-50LC14 50" Rear Projection...
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Panasonic TV without picture
If the sound stays on try just going up and giving it a "whack" on the side, a pretty good one. If the picture springs back to life it is likely a poor solder joint.
Those sets and many others are prone to cold solder around the vertical IC due to the heating/cooling cycles and high temperatures inside a TV. If you hit it and you get a picture back it likely just needs to be re-soldered.
May 23, 2010 | Televison & Video
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I would look to see it this set has a bulb, common problem when set's won't turn on on rear projection lcd.
How old is the set, most bulb should last 2000 hrs, depending how often you have turn the set on and off. Most set's dont' have this problem they have slow turn on bulb, I love panasonic I feel there one of the top brands and have excelent picture.
But keep in mind new technology has there problem, more gagit more problem just like vehicule, and panasonic ten to push this to the max. Panasonic also then not to help when ask question , they just don't want to help technician.
Most tv's this day's has a life expentasy of about 7 years, the best one's would last over 12 years and the cheaper brand I keep seeing or made in china, lucky if you get 2 years.
Jan 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
PT-47WX49 47 in. Rear Projectiopn Problem:
get in to the eprom setings and see if any adjustments have changed.the service manual can be gotton at
Aug 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
