Question about LG Televison & Video
How to fix VHS ejecting issues for a LG V782W
Hi all, Im having trouble finding a way to fix the issue i have with this vcr/dvd player. its not damaging the VHS at all and ejects it to a point just leaving a tiny bit outside the machine. though as soon as that happens it takes the tape back into the machine and it reacts as if it knowns theres a tape there when there shouldnt be so it continues to try to eject it until it kills the power to the machine. the only way to stop this from happenning is quickly pull the tape out when it first pops out but the cover plate may not close properly after that leaving it either completely open or just abit ajar.
shadow5599
  • 51 Answers
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
SOURCE: VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Posted on Mar 19, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
  • 4234 Answers
SOURCE: Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Posted on Aug 31, 2009
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Can I upgrade an LG v782w combo DVD/VHS unit to play DivX Discs?
Turn on the DVD player with no disk, wait until the 'no disk' label pops up then press
1. 'Pause'
2. '1'
3. '4'
4. '7'
5. '2'
if That Don"t Work Im Out Of Options
Jul 07, 2008 | Televison & Video
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Oct 18, 2007 | JVC HR-XVC19S DVD Player/VCR
DVD/VHS Selection
turn of the power on wall, and wait 5 mins, then try again. i had same trouble with not being able to eject or play dvd, i turned off player at wall and it worked fine again.
Sep 25, 2007 | LG V181 DVD Player/VCR
Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Apr 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
VCR part not responding
This is a common problem. Also the DVD unit has a High failure rate due to the spindle motor going bad. CD's may spin very slowly or erratically and sometimes the CD might be hard to eject. The VCR may be very difficult to get out to work on, and I doubt that it is a broken or loose belt that is causing your symptoms so you will probably be better off just replacing it.
Dec 24, 2006 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
42 people viewed this question
Computer Repairing
Computer Repairing
