Question about Sewing Machines
My entire bobbin case, hook, and shuttle race won't stay in place.
  • Sewing Machines Master
  • 12,063 Answers
Difficult to assist without the make & model machine. Most machines have levers or latches that hold the parts in place. You can search for a manual by inputting:
Make Model manual
Posted on Dec 22, 2016
    Top Expert:
  • 50,093 Answers
Missing securing screws
take it in for repair and needle/hook timing adjustment
Posted on Dec 21, 2016
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
kent581
  • 87 Answers
SOURCE: Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Posted on Mar 18, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: Pinnock
I also have a pinnock sewmaster, here is a link to the instruction manual, hope this helps http://www.sewon.info/downloads8888/PINNOCK-FRIDOR-SEWMASTER.pdf
Regards
Posted on Aug 31, 2009
SOURCE: The top thread gets caught in the shuttle hook and
I am having same problem
Posted on Sep 27, 2009
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Apr 18, 2010 | Sewing Machines
Can't put back the bobbin case in a singer 7442, it get sotck
Put the bobbin into the case so the thread is feeding clock wise and through the guide on the case.
Lift the lever to hold the bobbin in place.
Insert the bobbin case into the race/shuttle, still holding the lever out.
Align the finger on the bobbin case with the opening in the race/shuttle.
You may have to turn the bobbin case a bit to the left or right for it to line up.
Once it clicks into place it should work without any further problems.
Feb 19, 2010 | Singer 7442 Mechanical Sewing Machine
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kent
Mar 16, 2009 | Baby Lock BL1556
Shuttle hook
Hello ZAckofun
The shuttle hook will be covered by a plate called the RACE. Its a flat steel plate that sits over the hook and is snapped in place by 2 black coloured snaps.
Looks like you are trying to operate the machine without the race on. try that and it should work.
Nov 27, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
