I have a PMP2000 Powered Mixer 800 Watt. The last two times I've used it, it has made a single POP sound even though the volume is off - like a voltage spike, perhaps.
I should add that before and after the noise, it works totally fine. But the POP is quite loud.
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
  • 63 Answers
SOURCE: Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Posted on Aug 09, 2007
  • 4234 Answers
SOURCE: Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Dan
Posted on Apr 12, 2009
  • 8 Answers
SOURCE: Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Posted on Aug 10, 2009
SOURCE: No picture after loud pop. Sound works fine
i have the same fault loud pop and no picture but sound is ok
Posted on Oct 28, 2009
My Behringer pmp2000 is now only giving an output through the tweeter horns of my speakers so the sound is very tinny. Any suggestions as to what might be wrong?
Your woofers are probably blown. To check plug a 1/4 inch or speakon into the speaker cabinet with the two bare wires exposed on the opposite end and touch with a 9volt flat battery if the driver doesn't move ir sound it's blown
Dec 15, 2014 | Behringer PMP2000 800 Watt 10 Channel...
Behringer PMP 2000 lost audio output
Sounds like a few capacitors have just blown, easy fix if your handy with a soldering iorn,
Aug 01, 2014 | Behringer PMP2000 800 Watt 10 Channel...
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 | Music
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Brand new, distorts intermittingly. Used same Speakers with other similer amps Mackie 808 Yamaha etc. with no problem . It sounds good when it does''nt distort
Common causes of this are improper level setup. You MAY be overdriving the inputs. Use the pad buttons to limit the input for higher output devices. Saturating the input(s) will cause bad distortion. Observe if any of the clip indicators are coming on. If they do, then use the pad buttons. If they still come on due to very high output device, you MAY have to use an external attenuator. Every mixer has different characteristics and some can accept a wider inout range than others.
Jul 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Some of my eq sliders are broke off and i was wondering if i could get just a nother circut from behringer if it is fixable Terry
Depending on how its built and if your good with circuits i couldnt see why not. If its under warranty though make em give you a new one
May 09, 2011 | Behringer PMP2000 800 Watt 10 Channel...
How can a PMP 2000 be patched so that both internal amps are used to power the monitors, and the mains are sent from the mainpre-out to another power amp, while using one internal eq for the mains, and the...
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Apr 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Is my Behringer Powered Mixer PMP2000 cooling fan suppose to run continuosly. It has a distracting hum in our small church. I don't remember it always running (fan) when we first started using it? Help :-[
Sorry, the fan is thermally controlled and USUALLY will run at low speed when unit is lightly loaded. In hot weather or driven hard it will run faster and louder.
Whatever you do, do NOT block airflow... these are a dual 400 Watt continuous amp (600 a side peak) and they need to breathe !!!
If you can duct cool air to it, that will help. You could also try sound absorbing baffles while maintaining adequate clearance for airflow.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
 Grubhead
Grubhead
