Question about Vacuums
Model EL7020 Power Button is getting harder to press every time we try to turn our vacuum on.
Is there a way to remove the three button switch cover so I can gain access the power button and repair or replace it?
  • 3 Answers
SOURCE: No power to vacuum motor. Switch need to replace.
See my response to "posted by bigbadben on Oct 07, 2007".
The cover that I referred to in my answer is a small plastic plate that covers the 'live' electrical bayonets between the electrical cord rewind spool and the motor. I did not make this clear in my first response. Before you start disconnecting any wires take a digital photo and/or draw yourself a electrical diagram. Save yourself a lot of time come reassembly.
Posted on Jan 08, 2008
nwj2468
  • 76 Answers
SOURCE: Need to replace power cord on Hoover vacuum.
remove the dirt container and look for screws.
Posted on Apr 19, 2009
  • 430 Answers
SOURCE: How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Posted on Sep 17, 2009
SOURCE: Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Posted on Jul 22, 2010
Vacuum Guru
  • 78 Answers
SOURCE: when the power button is
This is a common problem for the dyson DC08 & DC07 vacuums. The switch itself is a little bit weak and after a time just fails. Basically the only proper solution is to have the switch replaced. The switch itself is fairly cheap and is only a 10 minute job to fit. Normally by the time the switch is failing I would recommend replacing the washable filter too. If you live in Australia you can get any related parts from Nelson Vacuums or VacuumSpot.
Hope this is helpful for you.
Posted on Feb 01, 2011
Why won't my Miele 8310 vacuum switch on?
The problem could be a restriction in the brush roll somewhere. Remove the brush roll and clean it and the nozzle housing. It could be an electronic problem which is much harder to diagnose.
Apr 10, 2016 | Miele Vacuums
Now that I just fixed my Lux Legacy canister vacuum, I need help on my other Electrolux Regency Series upright! The vacuum works fine but the rotating brush does not work and the brush motor does not turn...
There are a couple rectangular holes on the bottom of the power nozzle, beside the wheels. These have tabs in them that need released with a standard screwdriver.
rogerpotts_10.jpg Once they release, turn the vacuum over and lift cover of power nozzle at the back. This pulls the front of the cover out of the lip on the "bumper".
Once this is done, you'll need to unscrew the screw at each end of the brush. Lift the brush out and thoroughly clean it, including the ends.
Check the wiring to make sure they're connected to the terminals of the motor. Also, check the belt for wear and tear. These belts can last for five years or more, but if it looks bad a good time to replace it is while you have the power head apart.
When reassembling the vacuum, ensure the belt is fitted properly around the motor shaft and brush.
Insert the front of the cover first, ensuring the edge fits neatly beneath the lip on the bumper all the way around. It takes a little manipulating to press the back into place. Make sure both tabs click into the locked position. Turn the vacuum over and reinstall screws. Try to rotate brush by hand a few times.
At this point, plug the vacuum in and turn it on. If the power head doesn't run, press the reset button. If the power head motor still doesn't run, it could be due to loose or disconnected wires that lead to the reset switch, a bad reset switch, or even a bad motor. The vacuum needs to be taken to the nearest Aerus Electrolux store for further diagnosis and repair.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Vacuums
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
Kenmore Model 116 Cannister Vacuum.Trying to get into motor area. Think belt is worn out. I have removed the front two screws under the hinged cover, but can not remove cover over motor.. Still attached at...
Under the cordwinder actuator button, are your other two screws. To remove this cover, take a flat tipped screwdriver and , very carefully, find the "tabs" (there are two) both on the front section under the button. Then, Carefully, press them in and back and up, in that order, one at atime, or both if you can. Your button should pop off, it can be a bit tricky, I know, it feels like it could break. But don't worry, they usually don't break. If you think that there is a problem with your belt, there is no reason to be accessing the motor compartment, for there is not a belt anywhere except the power nozzle, and if you press the circuit breaker/reset switch (while unit is running) located on the power nozzle, this will often solve problems with your belt. I hope i could help fixya! Let me know, thanks! Rene (the Vacuum Doctor)
Nov 18, 2009 | Vacuums
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
On switch will not stay down or on
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great, it should now stick when you press the power button. Replace it and reassemble, otherwise you'll need to get a new switch.
May 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
My dyson will not stay on when i press the button.
OK...so while I'm sure that hitting the power button w/ a mallet will work...I was having the same issue and felt uncomfortable hitting my very expensive Dyson w/ a mallet.
Here is what I did to fix the problem I have a DC17...I am sure instructions will vary by model Here is what you will need: 1. flat head screw driver 2. Torx -15 screw driver.
1. remove the dust tank  2.Pull the extension tube (handle) out (as if you were going to  vacuum a tight area.  3. there are 2 torx screws that you will have to remove 4. there are 4 retaining clips that you will use the flat head screw driver to unlatch.   5. After you remove the torx screws and release the 4 retaining clips, the front panel (that houses the power button) can be removed.  6. This will expose the actual power button itself.  Most likely it was jammed. 7. Once you think you have fixed it...test out your fix. 8.  If fixed...reassemble
Dec 29, 2008 | Sharper Image Dyson Slim DC18 All Floors...
Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Nov 17, 2008 | Dyson DC14 All floors Bagless Upright...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
