Question about Crafts & Hobbies
Can I attach a second track lock on to the same track to prevent train from slowing down at farthest point from transformer ? If so , how is it wired?
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Posted on Dec 25, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: I have a Multicontrol 115 volt transformer (4
I went to a train dealer.
Posted on Nov 21, 2009
  • 13 Answers
SOURCE: how do i wire the transformer? there are four
good grief..here is the real fix... 2 terminals are for constant "ON" voltage for powering scenery lights, ect. the other 2 are for the train,,,and the out put voltage is variable to the relation of the throttle handle on the transformer. Use a cheap volt meter ($9.99) and by reading the 4 posts t will be obvious which 2 are varable power and which 2 are constant voltage .........
Posted on Nov 20, 2011
technowee362
SOURCE: I have a Lionel ZW transformer older version
Just wanted to add a note to this problem you are having....Question is this...How big is the train layout and how many power clips do you have on the track??
Reason is being if you only have one power clip for the whole track, you will notice a decrease (slowdown) of the train in certain area(s) so i would recommend adding another power clip or two to your layout, also If you are using old regular O track, make sure you have the metal pins in all 3 railsHope this helps
Posted on Apr 06, 2012
Diode in blender,what its function
Most of the time a diode is to reduce the amount of electricity to something.
For example. I had an electric train.
The transformer made it go too fast, and it would jump off the tracks. I added a diode between the transformer and one of the wires to the track wire connector, and reduced the electricity to the engine, hence it slowed down to 1/2 speed.
God bless your efforts.
Mar 28, 2017 | Blenders
When my soon put his pennsylvania flyer train set he unhook the wiring to the fasttrack itself. How to we put in back on the fasttrack?
turn the terminal track(where the wires were connected) over,
you should see 2 screws where the wires were attached.
loosen the center rail screw, strip the wire with the red end back - 1/2 inch on the end that was attached to the screw, place wire around the screw & tighten. repeat with the other wire attaching it
to the screw on the outside rail where it was previously attached.
reconnect the terminal track to the rest,connect to your transformer
and play with your train.
Dec 11, 2014 | Crafts & Hobbies
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
How often should tracks be cleaned. Engine slows down after running for a while
It depends upon how much you run your trains. Run your finger or clean cloth on the rail. If you see a dark mark your tracks need cleaning. You can also run another set of wires from the transformer to the spot on the track furthest from the transformer. You can even run a third or fourth equally spaced apart if you have large loops and long and heavy trains.
Dec 04, 2011 | Lionel 40 Watt Transformer Train Set Track...
I have a Lionel ZW transformer older version 1955-1956, And lately my train loses power at one area of the track and then regains power again. This happens on both the outside and inside tracks.
This does not appear to be a problem with the ZW. The XFMR does not know anything about train location on the track. It appears to be a track connection problem on the center or outside tracks or both. One way to identify a bad connection is to take a parallel wire from the common and hot terminal of the ZW and connect directly to the area of track where the train stops and slows down. If this cures the problem then I recommend checking the tightness of the three track connections. For both FasTrack and Tubular, crimp slightly the pin receiving holes in the end of the track.
Note: For both tubular and Fasrtrack it is recommended that common track power for any one section be input to the track at more than one point. In this way one bad outter or center conductor won't cause the train to slow up or stop.
If FasTrack, you can solder directly to the tabs on the track underside for a permanent connection.
Aug 22, 2011 | Lionel Postwar Parts Zw-99 Transformer...
My new lionel train slows down on far side of the track
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Jan 26, 2011 | Lionel New Haven Freight Train Set
Need help setting up Lionel North Pole Central Christmas Train 6-30068--how do I attach the transformer to the track? It is on O gauge track and is transformer that came with set. Our manual is lost and...
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Nov 26, 2009 | Northpole Lionel 6-30068 North Pole...
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
96 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
