Keyboard shift 6 - Computers & Internet
Keyboard has aproblem
The keyboard will need to be replaced, no user serviceable parts. Go to www.ebay.com Type: make and model of your laptop refine search to keyboard.
Apr 23, 2012 | Computers & Internet
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Right shift key does not capitalize,left shift key is fine. 5 6 keys on letter keypad do not operate
It seems you must have spilled something on your keyboard. I suggest buying a new one. var fctb_tool=null; function FCTB_Init_62d08f39d8ff4f9cae277f63e2f72c56(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_62d08f39d8ff4f9cae277f63e2f72c56(document['FCTB_Init_3c408a929e794b45bb9f80f0a107404c']); delete document['FCTB_Init_3c408a929e794b45bb9f80f0a107404c']
Jul 20, 2011 | Samsung Computers & Internet
Some number keys also has 3 other functions. how do i use them. for instance the 6 also has ^ and question mark which i can't find.
You press shift then 6 to use the other function. it is called a secondary function. newer keyboard may even have up to 3 functions. Regards
Apr 04, 2011 | Acer NSK8458AN Keyboard
Keyboard issue
Please try fn+shift+Nmlock
or shift+scLlock
it should work. if not plz let me kno...
Dreamkam
May 16, 2010 | IBM ThinkPad T43 Notebook
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
I am using an external keyboard(lx710 corless) for my toshiba satellite m 3/5 laptop. When i remove the usb from my laptop and want to roam in my house using only the laptop, I have to restore the settings...
Generall there is a Fn Key somewhere, down by the Shift-CTRL-ALT Keys, or perhaps holding down the shift key, and tapping the required key will access the "Other" funtions of the keys.
Jan 24, 2010 | Gateway 2520915 Keyboard
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
THE KEYS ARE ALL SWITCH TO DIFFERENT CHARATERS WHEN I PRESS M GIVES ME 0
ok here from left to right top row esc f1 f2 f3 f4 f5 f6 f7 f8 f9 f10 f11 f12 prtscrn scrolllock pause second row ~ 1 2 3 4 5 6 7 8 9 0 - = bkspc insert home page up num lock / * - third row tab q w e r t y u i o p [ ] \ del end pgdn 789+ fourth row caps lock a s d f g h j k l ; ' enter 4 5 6 fifth row shift z x c v b n m , . / shift up 1 2 3 enter bottom row ctrl windows key alt spacebar alt windows right click ctrl 0. hope that helped
Oct 11, 2009 | Compaq Keyboard
IMB thinkpad numbers are locked on alpha keyboard
just press = SHIFT + NumLk / ScrLk
thanks UTKAL BISWAL
Apr 06, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Computers & Internet Logo
David Payne
David Payne
