Line busy error code
Attempt to FAX get line busy error code
checkitright
  • 1362 Answers
SOURCE: error code fax
check this link and go to error codes/fax error
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 27, 2007
Bubbabear64
  • 2794 Answers
SOURCE: fax line stays busy continously...
Are there any other phones that use that line? If you have a phone attached to the fax machine, is the reciever in the holster all the way?
Posted on Jul 06, 2008
SOURCE: Canon Pixma MX700
I had the same problem. Solution? I will sound stupid, but it worked for me. Check every phone cable. Unplug and replug it. I solved my problem by making my connections simpler. I think, one of my splitter was faulty.
I still not understand why. I tried to fax without any phones plug-on and it was not working neither.
I'm with "videotron.ca" for my phone line and I unplugged the line from the modem too, then replug it. Maybe it was just that!
A lot of people seem to have this problem. I called Canon twice and they made me change some setting in my printer but their solutions was not working. I put all the setting back to what they was and it still working now.
Posted on Nov 20, 2008
  • 16 Answers
SOURCE: Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Posted on Apr 26, 2009
goalie39
  • 469 Answers
SOURCE: Fax line is busy
check the hand set is correctly seated on its cradle.
Check the Hook button on the front of the machine.
Disconnect the fax machine from both the phone and power lines for several minutes, reconnect and try again.
UserGuide
.pdf">http://static.compusa.com/pdf/canon-FAXPHONE_L80-UserGuide.pdf
I have included a copy of the users manual in case you are missing yours.
Hope this helps
Ed
Posted on May 20, 2009
I'm getting error code 388 when I fax to one specific location - can fax to all other numbers but this one.
The fax machine has originated a fax session and detected a remote fax machine but has been unable to connect to it. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode it is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
or
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. I hope I have been able to help you. Have a NICE Day!!
Jan 26, 2011 | HP 1240 Plain Paper Inkjet Fax
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
Unable to fax to a certain number
She may have a digital phone line, such as DSL...Vonage...etc.
Sep 11, 2008 | Brother IntelliFax-2820 Laser Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Error 344- Fax Function
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
54 people viewed this question
k24674
jasbo
jasbo
