Question about Miscellaneous
Windows 7 pc *********** - Miscellaneous
  • Brett Duxbury
    Brett Duxbury Dec 21, 2016
    Hi joseph , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    you must be really frustrated with windows 7 as it got ********** out what is the difficulty you are experiencing with it ?
  • Andrew Taylor
    Andrew Taylor Dec 21, 2016
    He is after pirated software Brett. I already answered him in a dupe post.
How to download whatsapp on laptop
As WhatsApp was originally designed for phones the process adn solution are not as straight forward as you might think,
See the sites listed below:
Download WhatsApp For Laptop PC Windows 8 1 8 7 Install Whatsapp
Jan 29, 2015 | Compaq Computers & Internet
4 Proven Techniques to Reset HP Windows 7 password
<span>Forgot HP Windows 7 password? Don't be scared. You can follow these four proven techniques below to<span> </span><b><a href="">reset Windows 7 password</a></b><span> </span>on your own. Certainly, these four HP password reset methods will work in all versions of Windows 7/Vista/ XP and Server 2000/2003/2008.<br /> Technique 1: Reset HP Windows 7 password with Windows Password Reset DiskThis is an easy-to-use method to<span> </span><b>reset HP Windows 7 password</b>, however you need created a disk before<span> </span><a href="">forgot HP Windows 7 password</a><span> </span>. And the HP Windows 7 password reset disk will only work for the account that have created another ones.<br />To create a password reset disk, you can log on HP PC and enter User Accounts by clicking Start button, Control Panel, User and Family Safety, and User Accounts. Then you can click Create a password reset disk on the left pane (Just as shown on the below picture). A password reset disk wizard will come up, and then you can follow it to<span> </span><b>create a Windows 7 password reset disk</b><span> </span>for your HP PC.<br />When you forgot HP Windows 7 password , your need boot computer to enter Windows logon screen. You'll view the reset password option when you type an wrong password on the logon screen and press Enter. Click on the option and the password reset wizard will pop up to guide you to reset HP Windows 7 password.<br /> Technique 2: Reset HP Windows 7 password with Windows Password HintWhenever you create or change Windows password, there will be an opportunity to type a password hint to prevent forgetting password. When type a wrong password, you will see the password hint be displayed to remind you what login password is. This is the easiest way to reset your<b><span> </span>forgotten windows 7 password</b><span> </span>for HP.<br /> Technique 3: Reset HP Windows 7 password with Windows System Recovery OptionsApart from Create a password reset disk and password hint, the OS Recovery Options can also help you to<span> </span><b>reset HP Windows 7 password</b>. Apart from Windows installation disc or the recovery options provided by your HP PC manufacturer to access the System Recovery Options. You also can create a system repair disc by yourself.<br /> <ul> <li>1. Input the word of" system repair disc" into the search box in the Start menu and press Enter.</li> <li>2. Insert a CD/DVD into the optical drive and hit Create disc.</li></ul>This guide will help to create your HP PC system repair disc. Hence, if you want to reset HP Windows 7 password by this technique, please insert the system repair disc into the optical drive and reboot the PC via this disc. And then choose the System Recovery option that will displayed on the prompt list of Windows installation.<br /> Technique 4: Reset HP Windows 7 password with Windows Password UnlockerIf those three methods that I mentioned above can't help you out. Maybe you need try this proven Windows password recovery tool named<span> </span><b>Windows Password Unlocker<span> </span></b>which can reset any windows password safely and instantly.<br /> <ul> <li>1. Download<span> </span><a href=""><b>Windows Password Unlocker</b></a><span> </span>and install it in any unlocked computer.</li> <li>2. Create a bootable CD/DVD or USB flash drive with the software.</li> <li>3. Set CD-ROM or USB device as the first boot device in BIOS for your PC.</li> <li>4. Boot your lock PC from the created CD/DVD or USB flash drive and then<span> </span><b>reset HP Windows 7 password</b>.</li></ul>Are you relaxed on HP Windows 7 password reset? Next time, you can do it yourself if meet with the similar issue.<br /></span>
on Apr 02, 2011 | Computers & Internet
Windows 7 Upgrade Considerations
Depending on the version of Windows you're currently running, installing Windows 7 on your PC may be a lengthy process. Run Windows 7 Upgrade Advisor to make sure your PC can run Windows 7, and then review the information below prior to buying or installing Windows 7 on your PC.
Use this chart to determine whether you should do an upgrade or custom (clean) installation.
on Dec 28, 2009 | Computers & Internet
Whatsapp on pc wth ths numbers 0833162189
Whatsapp is a chat program for phone, but here they offer a program for your PC:
On your own risk.
wat is het landen nummer? WhatsApp for PC Download Windows 7 8 Computer without Bluestacks
Jan 27, 2015 | WhatsApp Messenger
How to bypass admin passwords on windows 7
Have you lost windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset Deluxe as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove Windows 7 password on the operation interface and logon PC without password.
Jun 21, 2012 | Dell Inspiron Computers & Internet
It is not recoginsed in windows 7 due to non installation of driver as there is no driver for windows 7
Hi... Hard time to initiative your pinnacle pc tv on your pc
check first if your pinnacle deluxe is compatible with windows 7 then try to download the correct driver for windows 7... to do so type on any url browser exemple: download pinnacle pc tv deluxe drivers for windows 7 good luck
Oct 25, 2010 | Pinnacle pctv deluxe TV Input
PC Relocator: Windows XP to Windows 7?
No. PCRelocator requires IE 6 and Windows 7 is IE8
Nov 18, 2009 | Eisenworld Alohabob PC Relocator Ultra...
Why my acer e500 cannot install 64 bit window 7 it say no driver when need to choose hard disk to install
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here:
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
Nov 05, 2009 | Acer Aspire E500 PC Desktop
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
