Dansat front load 7kg in problam show on display E5 and machine are not working
SOURCE: over loaded the macine
Have you tried unplugging the machine for a minute to reset it?
Posted on Dec 09, 2007
SOURCE: Our samsung j845 front load washing machine won't
Posted on Sep 29, 2009
  • 1474 Answers
SOURCE: I have a Samsung Front Loading Washing Machine 7kg
Remove the lid and check for fill hoses split....This could account for both faults..Check inlet hoses not loose...Please leave feedback
Posted on Apr 08, 2010
  • 42 Answers
SOURCE: Lg wd80160fu front loading 7kg washing machine when power is on shows (cl) on it
cl is child lock......look for your units user manual and reset the child lock....usually its one button to push and hold in.....but some lg's have two buttons......just look at your user manual and reset......
a feed back would be good if this helps
Posted on Jun 07, 2010
  • 15935 Answers
SOURCE: WD8074-FHB washing machine SE on display
LG washing machine error code SE indicates a “motor fault” although the code also says it could be a main PCB fault.
They recommend to... “try the motor first”.
It’s vague and you really need an engineer to try and sort this one.
You can’t possibly justify “trying the motor first” if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
EOB showing on washing machine
That's E08 (E-zero-eight). Speed sensor on back of motor faulty, or the wiring to it. Can also be a broken magnet in the middle of the sensor coil.
Feb 16, 2015 | Hoover Optima 7 OPH716DF White 600 mm...
What is error code F11 ?
An E11 error code indicated there's an open circuit on the dryer heater or a module issue it's a good idea to check the wiring from the sensor on the top the drum to the circuit board as this can become damaged during the spin cycle.
Nov 24, 2014 | Hoover Optima 7 OPH716DF White 600 mm...
Showing error E5
E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
Jul 29, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
Samsung washer E5 message
my washer machine work perfect the day before, they gimme a code e5 and stop working no power and look the door
Jun 20, 2012 | Samsung WF337AA Front Load Washer
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
Washing machine Lg 7kg WD 1256 problem LE sign direct drive the cylindre move difficult and stop
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Jul 10, 2011 | LG WM2487H Front Load Washer
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
How to upgrade Dansat 8400 PVR i need it thanks
Link to software v 3.0.3 for Dansat 8400 PVR: DSR-8400 _090328.rar
This solves the problem with displaying 16:9 format.
Jul 23, 2009 | Televison & Video
Washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Dec 12, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
