Question about DeLonghi Coffee Makers & Espresso Machines
I need a free Delonghi Perfecta cappacino service manual
  • 276 Answers
SOURCE: I desperately require an User Manual for a
Posted on May 26, 2010
  • 1833 Answers
SOURCE: my delonghi perfecta plus says
According to your problem, the 'Close Door' message indicates the service door is open. So first make sure that the service door is closed perfectly. If the service door is closed but you get the same error again then check the infuser is inserted correctly.
Open the service door
Remove the drip tray and the grounds container and clean it. Unlock the infuser and pull it out.
Wash the infuser under running water, without using detergents.
Clean the inside of the appliance thoroughly. To remove coffee encrustations from the inside of the appliance, scrape with a plastic or wooden fork, then vacuum up the residues with a vacuum cleaner.
Replace the infuser by sliding it onto the supports and pin at the bottom, then push the PUSH symbol fully in until it clicks into place.
Then close the service door perfectly. If it doesn't solve your problem then reset the settings of the machine. It will solve your problem.
Posted on Aug 13, 2011
SOURCE: the door to my DeLonghi
I hope you have solved this problem by now... The door not closing properly happens when coffee grounds build up in the middle of the machine. It tends not to get everything into the waist box. You need a chopstick to fish out the grounds from behind/under the central column of the machine. You'll find a lot of coffee packed in! Then the door will close.
Posted on Oct 22, 2011
SOURCE: How do I descale my Delonghi Perfecta? Can't
The manual is no longer available at that link. It's better to post an answer than to simply point to a URL...
The answer:
1. Fill the tank with descaling solution (or a vinegar solution, which voids your warranty, but seems to work well...)
2. Power on.
3. Hit the P button (Program). The display changes; instead of the usual icons, you will see the "clean" icon, which looks like rain drops in a circle. (This is for rinsing the coffee drip spigots). Turn the selector wheel to switch to it an icon that looks like a bunch of dots between two vertical bars. This is the "descaling mode."
4. The bottom left button now says "Esc" next to it, and the bottom right is the OK. Hit OK to confirm you want to descale. Then dump the drip pan and put a large container under the WATER spigot (not the coffee drip spigots.) Your descaling solution will come out hot and hard. The machine may pause and re-heat at times, to make sure it's very hot. The solution is hot and acidic - BE CAREFUL! It will go through the entire tank, so use a big container, or be ready to switch it out - or put your machine over the edge of your sink for the job.
5. When the tank is empty, the machine will ask for a refill - this time give it clean water for a rinse. Hit the OK; the entire water tank will be used to rinse.
That's it!
Posted on Jun 03, 2012
  • 78 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
From the question I understand that the steam jet is rushing into the cup but it is not able to draw milk. The jet of steam pulls the milk from the container (within a reasonable distance from the frother). With proper air mix from the air inlet in the frother, it generates foam. Suction of milk is enough when the milk tube connection at the frother end is airtight. Air sucked into the frother with milk (due to loose connection) reduces the suction of milk. Please try the following:
1- Make sure that the passage of milk between the milk container and the frother is not kinked.
2- Make sure the connection of the frother to the steam outlet is airtight. Air sucked in at this connection also reduces the suction of milk from the milk container.
3- Make sure the tube drawing milk from milk container to the frother is airtight at the frother end.
An extra suggestion to a related matter: Many operators feel that the steamed milk is not hot. This happens when the flow of milk id more than the steam can heat. Reduce the flow of milk for hotter foamed milk.
First slightly pinch the tube between finger and thumb to reduce milk flow. If that results in a better temperature of milk filling the cup, then you need to find a flow constrictor device.
The flow constrictor is a simple bushing with a hole through it to allow milk tube to pass through. There a screw (metal or plastic) threaded through its wall that can be tightened to pinch the milk tube and reduce the milk flow .
Please check the following link for the flow reducing device: Services Unlimited Inc Parts Guru
Posted on Oct 20, 2014
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Capuccino button has fallen inside panel
look up parts diagram DeLonghi Perfecta ESAM5500 download file, this will give you idea what needs to be undone and how to undo,often a combination of un-doiing screws and finding and locating hidden clips and disconnecting ,if button fell behind panel probably something has also broken that holds button in place .
Aug 18, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
While Brewing Bin Full Lights Came On
Check the housing where the bin sits is clean and free of coffee and other debris
Apr 18, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
