Question about Insignia Televison & Video
40" insignia tv manual serial number AAMA8YA000024
The picture on the screen is too large and cuts off information from the top and the bottom. Also, unfortunately we cannot find the manual and remote that came with the tv. We would like to decrease the size of the picture on the screen. Help!
  • 192 Answers
SOURCE: Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Oct 14, 2007
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Posted on Mar 22, 2008
MNfisherman
  • 11896 Answers
SOURCE: Picture is cut off at the top and bottom of the
Look on your remote to see if you have a picture butto or you can try and go to the menu settings and see if you can adjust the tv format from widescreen to regular or 4:3 or 16:9
Posted on Sep 23, 2009
tobibus2000
  • 506 Answers
SOURCE: my 47" LG LCD TV
its no big problem.I implore you visit the user's manual to see how to zoom and undo it. Get back if you encounter further problems.
Posted on Jul 15, 2011
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
The picture is to large for the screen. The
Try changing your Aspect Ratio, look in your manual.
Feb 09, 2010 | Televison & Video
Picture is too large. How do you change resolution?
On your television press the menu button to bring up the on screen display. Use the up or down arrows to find the aspect ratio control. Press the right arrow button to change the screen settings. Set the television to the best setting for your viewing pleasure. Hope this helps you with your problem. If you need technical assistance you can call Insignia customer service at this number: 1-877-467-4289. Hope this helps you with your problem.
Mar 29, 2009 | Insignia 37" LCD Flat-Panel HDTV
Picture is cut off
Try setting the set to 4.3 expanded on the aspect ratio. If that don't work try the other aspect ratio settings. That should make the picture fit the screen.
Jun 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
take zoom offf on dish and the tv it sel use normal 16 .9 ,mode when u push screen in to it use 1024x768 60 hertz ok
Jan 23, 2008 | Compaq Presario 1200,1600, Series CD...
Televison & Video Logo
22 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
