Do tvs that are not high def still have a picture from cable companies that push HD
    Top Expert:
  • Televison & ... Master
  • 43,064 Answers
Yes they will still show pictures .
Posted on Dec 21, 2016
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
Just set up the bravia and the picture is not crisp... directions for trouble shooting?
do u have a hd box, because if you dont then your tv is not going to project the look that you want. and another thing is that is that if you have basic cable then you will not have the desire look you want. another you can do is check with your cable company and ask them what are your high def channels and then once you turn to them channels your tv should look clear as water lol. but not all channels are high def. and most lcd flat screen tv come preset so when you turn to a high def channel it will say at the top 108pi or 1080p or 4080i or p but its depending on ur service provider
Dec 06, 2010 | Sony Televison & Video
My xbox 360 console will power up as normal and put out sound but no video. i have tried multiple tvs and cables with no luck.
are you on a standard def or HD tvs? b/c if you have the xbox set on high def, then you try to plug it into the standard def then you won't get a picture, but you will get sound. If you don't have a high def tv then go to a friends or someone you know's and plug it in to see if you get a picture.
Jan 26, 2010 | Microsoft Xbox 360 Console
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
How do you get the High Def. Picture?
Make sure you are using the red green and blue cables and not just the video
yellow ,red and white Inputs
the component cables will give you almost as good as the hdmi cable
The debate over monster cables and other is an on going discussion.
I personally have found little or no difference in the 30 dollar cables vs the 200 dollar cables
As long as you are running the component in on the tv you should have a very nice picture
Jan 11, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Toshiba 43H70 - making it HD
you cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Apr 03, 2008 | Toshiba 43H70 43" Rear Projection...
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
