Question about Panasonic Televison & Video
I have a Panasonic DMRBWT740 recorder how do you open the DVD door as there is no button on the remote thanks dave
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Posted on Apr 18, 2009
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
  • 188 Answers
SOURCE: remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Posted on Jul 24, 2009
SOURCE: Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Posted on Sep 21, 2009
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
Panasonic dmrbw500 bluray recorder. wont open automatically when button is pressed to open? can this only be done by remote?
No it should open by both methods. try turning unit off and then when restarting press eject.
Please rate my help++++Thanks for uisng FIXYA
Jun 11, 2010 | Panasonic DMR-EH57 HDD Recorder Player
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic dmr-e55 need code to work with our dish. codes listed in dish network book won't work?? HELP
We would be happy to help you with that. Here is a list of codes that should address your DISH Network remote to your Panasonic DVD Recorder: 627, 614, 777, 633, 554, and 628.
Press and hold the DVD/VCR button located on the top of the remote until all the mode buttons at the top of the remote light up, then release. Use the number buttons to enter one of the codes for your Panasonic DVD Recorder, then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. To check that the code works try several different functions on the remote to make sure it will properly operate your Panasonic DVD Recorder. Keep in mind that some codes may not be compatible with your equipment. If this is the case, please try the other codes listed for that device until you find one that is compatible with your equipment. We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 22, 2010 | Panasonic DMR-E55 DVD Recorder
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Compatibility of remote with DVD recorder?
If it doesn´t say Panasonic on the remote, you have what´s called a universal remote. It has to be programmed for your Panasonic DVD. I hope you got the instructions with it. If not, use the record button on the machine and try getting Panasonic´s own remote or another programmable one with instructions.
Feb 10, 2009 | Panasonic DMR-ES10 DVD Recorder
No remote--how do I record a dvd
On the lower right side of my unit there are STOP - PLAY - RECORD buttons
for operation without a remote control.
Dec 13, 2008 | Panasonic PVD4744 DVD Player/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
