Question about Sewing Machines
Inserting bobbin how do I insert the bobbin
    Top Expert:
  • Sewing Machines Master
  • 46,352 Answers
No idea here as I can not see the machine .
Posted on Dec 21, 2016
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I suspect the "housing" you refer to is not seated completely. Be sure to wiggle it until it slips into place. Once it is seated, the bobbin case should seat firmly as well.
May 02, 2017 | PfaFF Sewing Machines
The bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jan 21, 2013 | Brother Sewing Machines
How do i fix my sewing machine underthread keeps breaking
Nov 04, 2012 | Sewing Machines
Underthread in sewing machine keeps breaking
I am assuming your talking about the bobbin thread, so that is
the information I am sending you
Nov 04, 2012 | Singer Sewing Machines
The bobbin is not moving
try checking to make sure the bobbin is inserted correctly into
the bobbin case
make sure the bobbin is not inserted into the bobbin case backwards
if the bobbin is not in backwards and the bobbin is inserted correctly
then the hook and hook race should be checked by a repair
shop to see if they are damaged
Nov 01, 2012 | Sewing Machines
Kenmore bobbin issues
try these suggestions
Oct 25, 2012 | Kenmore Sewing Machines
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Problem inserting bobbin
Inserting bobbin into the bobbin case or problem inserting bobbin case into the shuttle?
Make sure the thread will feed from the bobbin clockwise and through the guide on the bobbin case.
Lift the lever on the bobbin case to hold the bobbin in place as you inset the bobbin case into the shuttle.
If the bobbin case for this machine as a "finger", this has to align with the opening in the shuttle.
If you cannot readily see this - move the bobbin case a bit to the left and right until it clicks into place.
Feb 20, 2010 | Necchi 6018 Mechanical Sewing Machine
The bobbin case is loose how do i put it back in
Hi
Thanks for using FixYa. Turn the power switch off before inserting or removing the bobbin. When inserting or removing the bobbin, the needle must be fully raised.
First open the hinged cover and pull the bobbin case tab and remove the bobbin case. Now hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Now pull the thread through the ****. Hold the bobbin case by the hinged latch and insert it into the shuttle.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
