Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
How to set the timing on a honda gx 670 motor with no timing marks
  • ray012965 Jan 17, 2017
    place crankshaft with key way at 6 o clock then insert camshaft with the tooth marked at 6 o clock you will have it timed.
  • 37 Answers
Hi, if it's a newer style bike, it could be like a newer car. Not possible to change the timing.
Posted on Feb 10, 2017
4 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 4 Answers
SOURCE: HONDA VIGOR
good luck that's a real biggy
Posted on Sep 25, 2008
  • 1757 Answers
SOURCE: HOW DO YOU LINE UP THE TIMING MARKS ON A 1991
Click on the following direct Link. It has the Diagrams and Instructions on how you line up the Timing Marks.
Let me know if this helped...
http://www.2carpros.com/car_repair_information/year/1991/make/honda/model/civic/1991_honda_civic_timing_belt_diagram_marks.htm
Posted on Mar 14, 2010
  • 1169 Answers
SOURCE: Rebuilding a honda 670 v twin no timing mark on
I am assuming your working a GX670 twin cylinder small engine.
There should be small dimple on the crankshaft gear. It is 180 degree from the keyway. Note the gear maybe on backwards.
here picture of the Honda setup from one their service bulletins.
Posted on Nov 04, 2014
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
Rebuilding a honda 670 v twin no timing mark on crank gear only cam!how can I time without that crank mark?
Nov 04, 2014 | Cars & Trucks
Gx 670 twin getting spark &gas wont start
Check the flywheel keyway, they will shear and cause the problem you are encountering.
Nov 22, 2013 | V-Twin Horizontal OHV Engine with Electric...
No fuel out of fuel pump on a gx 670
what kind of fuel pump, what kind of fuel tank, is there a filter b4 or after the pump, is there even a fuel filter, is the tank empty? all questions you should ask yourself because any one of them can cause this problem.
Sep 14, 2013 | V-Twin Horizontal OHV Engine with Electric...
Honda gx 670 chokes and sputters in thick grass or when goose throttle
It sounds to me like the carberator is a little dirty, drain the bowl and clean the main jet. Also while you are there check all the jets and make sure they are open not clogged.
Sep 09, 2013 | V-Twin Horizontal OHV Engine with Electric...
How do u set the ignition timing i have 2 marks then have 3 marks after it
Hello! Timing is set using the RED mark...It is the middle mark in the equally spaced group of three marks...Set with engine at normal operating temperature...All vacuum lines connected...670 RPM...
Guru............Saailer
May 04, 2010 | 1994 Honda Civic
Need timing mark settings on honda gx 240-242
if you have it apart you will see the gear on the crankshaft, inspection willreveal a dot onthe outer edge under the teeth of the gear . on the camshaft ,,on the gear that meshes with the gear on the crank,,you will see an arrow liike V, line the V up wth the dot ,and slide the cam shaft into place .the motor is now timed, reassemble the rest of it set the tappets , INLET .006 TH AND THE EXHAUST .008 TH . put some oil in kick her in ribs ,and while she warms up, you can have a beer. once warm check the tappets ,and it will be you decision as to whether you have a few more beers or go to work "youdoit"
Oct 27, 2009 | Honda 3000 Watt Portable Generator
I can not find the timing marks on a honda gx610??? Help!!!!
Make your own timing marks with a piece of chalk. The important thing to remember is the timing mark should be in the same place (if using a timing light) and not bounce around.
Jun 15, 2009 | V-Twin Horizontal OHV Engine with Electric...
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
425 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
