Question about Miscellaneous
Offered a cheap Lumix dmc-fz50 de-993 charger which came with a 3 pin +UK ***** plug flashes 3 times green,then stops. no charge in bat?
3 Suggested Answers
  • 1177 Answers
SOURCE: Lumix DMC-FZ50 will not power up. Tried 3
If this camera is like my FZ20, there is a socket to provide power to the camera from a mains adapter. The input socket is under the cover where the USB lead goes, and the manual shows a lead attached between this and a battery charger. My battery charger does not have this lead or DC output, though. The one that does is an optional extra, part DMW-CAC1. The manual recommends using the adapter to power the camera when it is connected to a computer, to make sure that a flat battery doesn't cause the memory to become corrupted.
My suggestion is that you attempt to power the camera through this DC power input, either with the approved adapter (maybe one of the chargers you are using has the output?) or with a generic one. I have successfully used a generic 9 volt adapter on my camera (positive center connector).
If it will power up with an adapter, I expect there is an issue with the connections in the battery housing. Otherwise, it might be a more fundamental fault.
Posted on Nov 16, 2010
SOURCE: My DMC-TZ3 battery charger green light is flashing, why ?.
According to the charging manual ( Panasonic LUMIX DMC TZ15 Operating Instructions Manual Charging Battery ) it could be caused by dirt. I've tried to clean my charger, now it works fine. No more blinking green light, just a constant green light.
Posted on Apr 12, 2015
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I can't get my camera (Lumix DMC-FZ50) to take pictures. Every time I turn it on it displays, "MEMORY CAR ERROR PLEASE CHECK THE CARD". I've tried 3 different SD cards from 2GB to 8GB and always get the...
Were these cards from another camera and now you want to start using them in the Lumix? If so, you must format the card in the Lumix to get it to work. This will erase the card so download any pics first.
Jun 13, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Re - Lumix Panasonic DE- 994 battery charger ??
Hi Cyril,
In theory this charger is fully automatic and stops the charging process once it detects that the battery has been fully charged (it will not restart charging until the battery has been taken out + put back in).
Of course, as with any electrical item, it's probably safest to unplug it if you're not planning to use it for a long time (e.g. weeks.)
Hope this helps.
Jun 11, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
I have an urgent issue of needing to display date Lumix DMC-FZ50 for pdf version of manual. The K or S means the color of camera you or silver. My wife has that camera, there is no way to display the date/time on the pictures themselves, you will have to look at the properties of the image. All images now contain certain data that is hard for the novice to change and might be able to be used in certain courts...good luck, hope it's not too late.
May 18, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
External flash for dmc-fz50
Okay, first off, Panasonic makes several external flash units that work with this camera. The FL360 seems to be the best buy, though at around $300 it is not exactly cheap. It has TTL and I am very happy with mine. I bought a cheap Sunpak to use with my older FZ30 but I think the voltage was too high, as it stopped working with the hotshoe. I would not recommend using any flash that is not rated to work with a digital camera. The problem is, almost all that are currently made are designed to work with specific camera models. So, the Panasonic flashes seem to be the way to go. There is also a FL500, which has a higher guide number, but it is close to $500.
Now, you don't necessarily need FL360s or even digital flashes to work with a slave unit. I have one I picked up at a camera store to use with my Sunpak as a second off camera flash. As long as you have a flash to trigger them (i.e. the built in flash, or something like the FL360) any flash with a slave trigger will work. One other possible solution is a device also made by Wein that allows you to use an older flash with a digital camera. It reduces the trigger voltage and prevents damage to the camera. I have one on order, not to use for that purpose, but because it also allows one to use a plug in flash with a camera that lacks the appropriate place to plug the flash in. I hope that helps.
Mar 17, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Battery Wont charge
I have the DMC-TZ1. The charger is labelled "Panasonic DE-A25 battery charger". It has 3 contacts where the battery fits in. With no battery in place, the voltage between the top and middle pins is 2.61 V. The voltage between the middle and bottom pins is 2.19 V. Check those voltages. If they are very different from mine, I rather think the charger is not working. You can buy the batteries for very low prices on ebay from Hong Kong and other asian sources, but I've been told by someone who tried them that they do not work. Perhaps you have run into one of those. If you can find someone else with the same battery, a quick swap will tell you if your camera is okay. I got my camera on ebay and it works perfectly.
Jan 03, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
