Question about IBM Infoprint 1572 Laser Printer
933.00 Service Printhead Error, I had a paper jam removed at a service center. the jam was cleared for 89.00 now I get an error as menttionded above. Genuine IBM high yeild print cartridge. Has plenty of toner.
    Master:
    Sergeant:
  • 226 Answers
Take the toner out and shake it or try to replace it with a new one
Posted on Jul 21, 2009
Unable to print 50
Error 50: The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam.
See here for illustrated instructions on how to clear a paper jam.
If the problem still continues after clearing the paper jam it could mean a problem with a sensor and you may need to contact a service representative.
For future reference a list and explanation of Error Codes can be found here.
Trust this is helpful.
Jan 04, 2011 | Brother MultiFunction Center MFC-440CN...
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
My CAnon MP 610 has a service error 6A00. What is
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Office Equipment & Supplies
I am receiving error message of : 86:01 Possible paper jam
Most times when this error occurs it is because of one of three things:
1. Paper jammed in the carriage path that prevents the printhead from moving all the way from left to right. Check closely on the far left and right as paper can be pushed into the interior of the printer by the service station.
2. The printhead cover was not closed properly and the metal ring that that the blue handle is supposed to engage in is catching on the side of the printer.
3. The drive belt has either come off the track or broken. Open the lid and check the black rubber belt that drives the printhead assembly. It should be taunt. If it is loose there is a problem. I have had several 1100 series designjets throw their belt off the tension pulley. You can sometimes reseat it but my experience is that it will get thrown again. If you replace the belt, replace the tensioner at the same time.
Dec 07, 2009 | HP Designjet T1100ps Printer
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Service error 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer malfunction
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 03, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
IBM Infoprint 1572 Laser Printer Logo
1,678 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
