Question about Garden
25 cc leaf blower . I have installed new plug new ignition coil and fly wheel with .010 gap . And I still have no spark . What's left to do ?
  • Michael Blandford Dec 21, 2016
    And checked switch with meter and is ok !
  • 22 Answers
How are you checking for spark. Best is to use inlne spark tester. If laying plug on plastic housing will never get spark because it is not grounded. Rere to have to replace coil and almost never need to replace flywheel. Unplug wire Going to stop switch from coil. If wire is grounded out or switch is bad not spark.
Posted on Dec 28, 2016
    Top Expert:
  • Garden Master
  • 48,298 Answers
Check the wires to the stop switch
if they are grounded anywhere that will be the problem
Posted on Dec 21, 2016
SOURCE: Spark Plug Gap
craftsman 25cc blower vac model 358.797 replacing fuel lines, cannot remember small goes to
Posted on Apr 11, 2009
  • 33 Answers
SOURCE: what's the gap setting for the CD ignition
.005 to.008
Posted on Jul 12, 2009
  • 148 Answers
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Posted on Jul 13, 2009
  • 718 Answers
SOURCE: I have an 28 cc McCullogh leaf blower which will
Check for spark in the new spark plug, if you have spark clean the carb fully and try again. make sure you have correct mix of gas to oil and it is not old use fresh gas oil mixture. Good luck pal.
Posted on Jan 24, 2010
  • 5568 Answers
SOURCE: craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
Posted on Oct 22, 2010
Igition coil gap for craftsman model 536886621
ALL ignition coils are gapped at about .010 or ten thousand. Rule of thumb, normal business card inbetween flywheel and coil
Dec 21, 2013 | Craftsman 536.886520 Snow Blower
Ignition assembly gap
do you mean the gap between the coil and the fly wheel?
Nov 22, 2013 | Craftsman 2 Cycle 30cc Backpack Blower
Replaced the ignition coil & also the spark plug, also replaced the gas. set the ignition gap to .010 or close
you didnt specify the problem but if you r having difficulty getting it to run you may want to check your fuel lines for minute cracks and splits as this is the number 1 cause for these machines to not run properly
Aug 15, 2011 | Homelite Garden
No fire to spark plug
You will need to check the magneto air gap. That is the distance between the magnets on the flywheel and the legs on the ignition coil. A standard setting is about .010"-.012". That is about the thickness of a standard business card. You will have to remove the cover(s) to access this. The two items cannot be rubbing each other. The smaller the gap, the stronger the spark. Coil failure is rare but it does occur. Also, check the wiring on the On/Off switch and the subsequent wiring going from the switch to a terminal on the ignition coil. The problem is either in the air-gap, the coil, the associated wiring, or the plug.Process of elimination will get you there. Make absolutely sure you aren't getting any spark. A spark-tester is recommended for this purpose.
Dec 02, 2010 | Echo Garden
Getting no spark on my stihl sh85 blower/vac
You will need to check the air gap at the ignition coil/flywheel. It should be about .010"-.012" where the magnets in the flywheel pass under the coil legs. That is about the thickness of a regular business card. So, some disassembly will be required. If the gap is closed, or too large, you would have no spark. If the gap is OK, then the coil may have failed. Make sure the screws holding it to the engine are tight, and if you remove them, you may wish to use threadlocker on them, so they don't vibrate loose and cause the gap to change. If you need more help adjusting the air-gap, please post back.
Nov 23, 2010 | Garden
Hello I have a POULAN PPB430VS leaf blower No spark. Replaced plug, no luck, replaced the kill switch, no luck, replace coil, no luck. still getting no spark. Do you know the gap on the magneto points....
Should be about .010 magneto to pickup gap. But leave the wire to ignition module loose from switch at the module, as wire could be grounded.
Jan 12, 2018 | Garden
Model TB320BV 2-cycle blower.
there is no set gap realy what i do is put a thin bit of carbord inbetween the coil and fly wheel so there is say 25th of an inch of gap dont set it so tight that the fly wheel hit's the coil or it will distroy it there needs to be a very small gap and it will work just fine,,ok?
Jul 27, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Weak spark
check the gap between flywheel and coil should be check magnet on flywheel.let me know what you find out.o if spark still weak change coil.let me know.ok
Jul 23, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No spark
Check your armeratur air gap. Where your flywheel is, it is a magnet on the fly wheel that when it goes around the armeratur it sends a spark, the depth needs to be business card size gap from the flywheel. If you remove the pull start housing you will see the spark plug wire running to the armeratur by adjusting that closer or farther away you get more volts which means more sparks. If that doesnt work replace the part and you will get spark.
Feb 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
