Question about Kenwood Radio Communications
Kenwood TK-3402 blinking red only on the programmed channels
I can read and program the radio. But when I turn it on it doesn`t give any sound and doesn`t transmit or receive. The red blinking happens only when i put the channel selector on a programmed channel. if I choose a non programmed channel it gives a solid red (Not blinking)
    Habit-Forming:
  • 9 Answers
The radio's microprocessor and synthesizer are told to show those indications when one of two conditions is met: either the frequency input is outside the operational range of the radio, or the VCO ("voltage controlled oscillator") is above or below its "lock range". The adjustments are physically small, quite fragile, and a very slight rotation in either direction can make a large change in the VCO. It's worth springing for a factory service manual so you can tell for sure where the meter the VCO is metered and how to set it to the correct range. And whilst I can't remember off the top of my head (I don't have that manual myself), many radios have separate Tx and RX VCOs, with separate voltage metering points and voltages to shoot for.
IHope that helps.
73,
Barney KL7HNY
Testimonial: "Thanks"
I have qty 2 IC-V85 handheld radios i just purchased new. One of them is working as planned testing136.000. The second one shows transmitting when i push the button but doesnt transmit?
At the Factory, they program test frequencies into the radios. They may or may not transmit to each other out of the box. They assume all radios will be read, then programmed properly. The test frequencies may not even be the same. Never transmit from the charger. All kinds of bad things can happen. Glad to answer more questions, but first, what are you using them for?
radiodude365@yahoo.com
Mar 14, 2015 | Radio Communications
I have a red signal light that keeps blinking in gp328 any ideas?
A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
Best regards.
Sep 17, 2014 | Radio Communications
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
I can only hear the others. When I talk they can't hear and my red anntenna keeps coming on when I push button to talk.
Assuming the antenna is mounted and grounded correctly,when you try to transmit/talk does your meter needle move to the right with your voice,if it doesn't make sure meter knob is set to receive/transmit or mod[modulate] does it move to right now,if not make sure the mic gain knob is turned up or if it is a power mic,is it turned up&have a fresh battery.The antenna light could mean high swr readings which you will have to adjust by tuning the antenna with the radio meter or external meter,you can search swr adjustment on your computer if unfamiliar..some antenna warning lights are factory set too sensitive but most times are telling you there is a problem.If all is set&tuned properly and you still can't get a local signal to respond, your radios transmit finals could be blown,which you'll need a qualified radio tech to determine..Good luck& 73's
Aug 13, 2011 | Cobra 29 LTD CB Radio
I have two motorola aux4100 radios. I can not get them receive. When I key it up to transmit, the red LED of the transmitting unit comes on and the green LED on the receiving unit comes on but does not...
I would guess you have a PL set on the receive side, and not on the Transmit side. So the audio is being blocked by the PL (as it is supposed to be!) Check your programming, make sure you have the same PL on tx and rx.
Jun 03, 2011 | Motorola AUX4100 2-Way Radio
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Keewood Protalk 2 way radio xls receives , but doesn't transmit
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Kenwood TK370N UHF FM HANDHELD RADIO
By keeping the PTT button pushed, if you get a rapid beep and the red led is blinking, sounds like a bad battery. Batt voltage is a nominal 7.5v. anything lower than 6.25v and the low battery beep starts. A rapid beep, and no red led blinking, an error in the transmit freq.
Mar 01, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
V-800 trouble
when i turn on my radio it keeps beeping repeatly nothing else happens
Jul 29, 2007 | Vertex iTECH iQfive iQplus Yeasu--VX800...
Radio Communications Logo
97 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
