Question about GE Kitchen Ranges
Ge profile spectra jbp48 electric range display panel is blank. When I turned the burner on, the display lit up. burner did not warn up, and when I shut it off the display went black. Fuses checked
SOURCE: GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Posted on Sep 23, 2007
  • 58 Answers
SOURCE: GE Spectra Profile - dual burner only has one temperature - HIGH!
you need a new switch that is in the control panel
Posted on Mar 12, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Posted on Nov 18, 2008
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
  • 61 Answers
SOURCE: Electric range displays bake probe
if you need a parts check out appliance parts solutions
Posted on Feb 10, 2010
Just the start button on my ge oven does not work. i can set the oven temp but when i push start nothing happens. does this mean i need to replace the key pad
If you unplug the machine and take the control panels back plate off there should be a tech sheet in there that can give you a detailed walk through on how to check everything and isolate the actual problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | GE Profile Spectra JBP48 Electric Kitchen...
Large burner stay on high will not turn lower
You have a bad switch and will need to replace it.Just be sure electric is off before attemping repair.
Jun 08, 2011 | GE Profile Spectra JBP48 Electric Kitchen...
Broiler element will not cut off...
Here is a tip that I wrote about why an electric oven will not shut off.
Electric Oven Problem Oven will not shut off
heatman101
Apr 26, 2011 | GE Profile Spectra JBP48 Electric Kitchen...
The electric igniter continues to click (ignite) even after the stove top burner is lit.
The switches for the ignitor are in the control knobs for turning on the gas...does the unit do it on all burners or just 1...if just 1 then the control switch assy will need to either be cleaned or replaced
Jan 22, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra JBP2AWD (2002?) and the oven does not heat - but the stove top still works. Anyone have any ideas or where we can find a manual?
Heating element is probably broken. You can use a continuity tester to see if yours is damaged. You can look at them and see if they are damaged, look for bends, cracks or breaks. Easy to replace, cost around $45.
Sep 28, 2010 | GE Profile Spectra JBP48 Electric Kitchen...
I have an older model GE Profile Spectra electric oven/range. It is beeping, and displays "FO" next to the clock. What does this mean, and how can it be fixed? Thanks!
This indicates either a stuck button if not the ERC needs to be replaced. The ERC is the Electronic Range Control.To check for a stuck button press each button one at a time and see if you can feel the slight click. If you have a stuck button you will need to replace the keypad membrane. Both are easy to replace. You can get diagrams and illustrations at www.appliancehelponline.com by entering your model #. All parts come with installation instructions.
Apr 11, 2010 | GE Profile Spectra JBP48 Electric Kitchen...
Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
