Question about Vacuums
Canister attachment to motor
The canister is crooked, the machine starts to run then stops
2 Suggested Answers
  • 8 Answers
SOURCE: My progressive canister stopped
buy anew one
Posted on Nov 29, 2009
With my Dyson D23, my carpet power head attachment runs intermittently until it stops working all together.
Hi Megan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC23. From your question, I'm not sure if you own DC23 Motorhead, which has a motor-driven brush bar, or DC23 Animal, which has a turbine-driven brush bar.
You can find online troubleshooting guides for both of these machines on our Support site. I'd encourage you to select your machine from the list, then follow the diagnostic checks shown:
http://www.dyson.co.uk/support/cylinders.aspx
If you'd like further advice from our experts after you've given this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 16, 2013 | Dyson DC23 Bagless Canister Cyclonic...
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dynamite Quick Vac there is no suction
If it sounds like the vacuum motor is running then you have a clog. Clean out any hoses where a clog may be. If the vacuum motor does not sound like it is running then you will need to take it to a vacuum repair shop. Or you need to make sure the canister is attached correctly. If the canister is not fitting correctly then you will lose suction. Hope this helps, post back.
Jun 27, 2008 | Vacuums
Cloged, will not pickup Hose also cloged no suction
Generic problem for all Vacuums
Clogged, will not pickup Hose
Clogged, will not pickup Hose also clogged no suction
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I’m not sure if you have a canister or an upright but there are thing you can check on both machines, canisters – you can check the suction from the end of the hose and work your way back to the canister, start with the end of the hose, then remove the hose and check the suction on the vacuum – most clogs are in the hose – if you have a hose clog run a steel ball thru the hose to see if goes thru all the way if it does than check the bad and the filter, if those are ok you may have a bad motor. If it is an upright, make sure the height adjustment is correct and is adjusted correctly, then use the steel ball and run it thru the attachment hose to see if that is blocked or clogged. Then check the belt and the extension wands to see if there is a blockage there as well, if you have good brushes and the tone changes from high to low and the brushes are actually hitting the floor, then you may have a motor problem and then you might have to replace the motor or fan assm. I hope this was helpful.
Apr 21, 2008 | Vacuums
No suction
No suction
no suction
Dyson
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
Dec 23, 2007 | Dyson DC05 Cylinder Bagless Canister...
Starts and Stops
I WANT TO THANK THE PERSON THAT POSTED ON MARCH 25 2008 ABOUT THE PROBLEM HE OR SHE HAD ABOUT THE HOLE THE SIZE OF A PIECE OF PENCIL LEAD IN THE PLASTIC LINING FOR THE BAG. WOW!! I ALSO PUT A PIECE OF TAPE OVER IT AND IT NEVER RAN BETTER! I WOULD LIKE TO PERSONLY THANK THEM!! MY EMAIL IS.. donniemon@sbcglobal.net
Dec 02, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
