Question about Winter Sports
So I have a 2005 REv 800 the wont start without juice then when it starts it idles around 2500 RPMs... if I turn the rpms down the sled dies and i have to juice it again to get it to start
It has crank shop dual exaust and v force 3 reeds with stock air box
SOURCE: 2004 Ford Ranger Low Idle
I figured out what was going on. supposedly on ford rangers the Idle Air Control Valve (IAC Valve) goes bad. i got a trouble code looked it up and sure enough it is the IAC Valve. Under 100 bucks for the part
Posted on Jul 13, 2008
Acuraking
  • 42 Answers
SOURCE: 93 honda civic ex sputtered and died while driving
Is there any white smoke coming out the exhaust? Sounds like the same problem my friend had when he warped his head on his 91 civic. Any overheating at all? Otherwise another guess would be maybe a bad catalitic converter that clogged up. Hope this helps any, good luck
Posted on Nov 12, 2008
SOURCE: 1990 Toyota Celica GTS. Idle races too high
sound very much like a vacuum leak.... also maybe your timing is off? possibly advanced? try retarding it with the distributor if thats the case...
Posted on Feb 01, 2009
  • 1071 Answers
SOURCE: Integra revs RPMs when idling
idle air control motor or just a plain old vacuum leak
Posted on Jul 21, 2009
SOURCE: rendezvous 04, the rpms stay idling high without pressing gas.
BUICK RENDEZVOUS IDLES UP REALLY HIGH...WITHOUT PRESSING GAS. WHAT IS THIS?
Posted on Jan 03, 2010
How do i adjust the carburetor
there will be a plug at the side top of the fuel bowl that you remove to check and adjust the float level while running
the float level is adjusted by the bolt at the top of the cover above the needle and seat adjust until the fuel is level with the threads of the plug
screw that mixture screw/s in all the way then back out 1 1/2 turns
start the engine and adjust the idle speed by the screw on the accelerator lever
set to around 800 rpms
adjust the mixture screw in until the rpms start to slow
now screw the mixture out until the rpms again slow
mixture adjustment is achieved by turning the screw back in 1/2 the turns that you used to turn it out from the slow in position to the slow position out
again adjust the engine rpms by the accelerator screw to the 800 rpms
most engines idle between 700 and 850 rpms unless and efi engine which have around 850 -950 rpms range
Nov 19, 2015 | Holley 1986 86 Dodge D150 Fuel Pump-1986...
1994 SL1 Code 14 hard cold starts,and revs to about 2500 Rpms onstart then dies.
They make a connector for the sender unit and they have to usually be replaced. Watch which way it goes on since they are a little cumbersome plugging back on...I prefer soldering the new connectors on too.
Jan 06, 2013 | 1993 Saturn SL1
Ok got a 96 s10 2.2 when it first starts up it has a rough idle then it clears up, then whenu rev it up it does fine but when the rpms drop down it starts a rough idle and it wont rev up near as smoot
had same problem in 97 dodge truck turned out it was vaccum leak hard to find sprayed either around vaccum lines when idle went up found tiny hole in line
Sep 22, 2012 | Chevrolet Vehicle Parts & Accessories
Start car and the idle goes to 3000 rpm, holds there for around 12 seconds or so and then comes down to around 1200. when driving if stopped and you put the car in park or nuetral the idle will go up to...
it sounds like a vacuum leak to me, my car had the same problem but when i changed the hose that connected the valve cover to the fuel injectors the rpms dropped back down to about 800 rpms
Sep 17, 2010 | 1999 Saturn SL
My sled bogs down going up hill or hitting the break
i have 1996 ultra sp runs great till i hit 80 mph then it starts to bog .
Feb 21, 2010 | Polaris New Genuine Polaris Snowmobile...
Rendezvous 04, the rpms stay idling high without pressing gas.
Sep 30, 2009 | 2004 Buick Rendezvous
1994 mustang gt cuts out
have you been tuning it? look for the vacuum hose you knocked off.
Mar 01, 2009 | 1994 Ford Mustang
With clutch pushed-in, RPMs start to go up to around 2000-2500
if it isnt the iac probably the pcv valve positive crankcase vent. it is on a vacuum line somewere under hood. or check the air cleaner, the hose with the small filter underneath the air filter. i take its fuel injected?
Feb 16, 2009 | 1987 Ford F 150
Winter Sports Logo
128 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
