I bought router from your branch how do get other emails of other computers to own laptop your branch could not help
  • Brett Duxbury
    Brett Duxbury Dec 21, 2016
    Hi michiel jacobus brand van deventer, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    We do not sell routers !
    We do not sell anything we help people !
    What is the make and model number of the router ?
    Is it a wi fi router ?
    Does it have a default ssid name on the label of the router ?
    Does it have a default WEP key on the label ?
I need my swift code of the bpi bank island pateros branch
for the swift code u will need to contact the bank personally or email them your query and they will respond to your query.
Hope this helps u.
Rate me if u find this helpful.
Jun 11, 2011 | Computers & Internet
I have two Cisco routers one is a 501Pix(located at branch Office), the other is a 515E Pix (located at main office). I've configured a vpn tunnel to the router at the main office. The router at the branch...
  1. Please check whether the Tunnel Phase 1 and Phase 2 are Up.If Not Proceed Next, if Yes Proceed to point 4
  2. Please check the peer IP is reachable
  3. Please check the configuration and the encapsulation method used
  4. Check whether in the Match Address whether the IP has been Allowed If Yes Proceed Next
  5. The Branch PIX will be in the Outside interface of the Main PIX, security Level will be enabled so do NAT. If Yes Proceed next
  6. If unable to ping enable the Inspect ICMP in the global policy to enable ping If Yes
  7. If all The above are done. please check the routes between the 2 remote computer.
Please check all the above point, surely your problems will be solved
Feb 26, 2011 | Cisco PIX 501 Firewall
Problem with sharing router
If you are referring to a cable modem then you may be talking about using both the USB connection and the Ethernet connection. They will not work simultaneously. But if you have a router and branching your connection, then there should not be any problems. Just make sure that when you are accessing the Internet through a router that you make sure that your router's IP address can access the internet after that you leave your computer's IP at Detect Settings Automatically, it works for me
May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
I just bought a new laptop computer and I cannot remember my router password. I need a security key to enter into the laptop so I can connect to the internet. Router is Linksys Help Please ...
when computer goes to sleep it does not recugnise the linksys wireless device i have to remove the device then reinsert it please help me if you can.
Feb 15, 2010 | Computers & Internet
I recently bought a linksys wireless router i've
Make sure your wireless feature is turned on on the computer. There may be a switch on the edge of the computer somewhere, you don't say what kind of computer it is.
Find the wireless connection wizard on your computer and run it. Find it in your network folder in the control panel.
If this is too much, post a comment to this question and we will back up and start over.
BTW, if your laptop has a ethernet outlet (looks like a big phone jack), you can wire your laptop to your router.
I want to help you with this problem
Dec 08, 2009 | Linksys Wireless-G Broadband Router
Network setup questions.
You could program the MAC addresses of only the computers you wan't to be able to connect to the router. It seems like you could add the MAC of your girlfriends computer your business computer and any other specific computer you wan't to allow to connect and this would leave all your current securities in place. Here are instructions if this solution sounds like what you need.
Nov 21, 2009 | Linksys Wireless-G WRT54G Router
Can't access my encryption key anymore
You can try accessing the router setup page or the user interface of it byu typing the on the address bar of the computer that is wired to the router and working to the internet, of you can also call linksys tech support so you don't need to reset the router because they can tell you how to change and check all the settings on your router this is the number 800-3267114, but if you want to reset the router just press and hold the reset button of it for 10 seconds,,,,
Hope that helps.......
Aug 13, 2008 | Linksys Wireless-G WRT54GS Router...
Setting up a wifi router
Configure the router first using the desktop. Make sure the modem is connected to the Internet port of the router and the desktop to port 1. Just run the setup CD that came with the router and it will guide you through the setup process. You can also try to reset the router first by pressing the reset button at the back for 10 seconds then unplug the power to the router and the modem, wait for 30 seconds. Power on the modem first and wait for the lights to stop blinking, then the router. check if the internet works hardwired.
Hope that helps.
If not, tell us more. Who is your ISP (Internet Serivce Provider)? Is it a cable or DSL?
Jul 24, 2008 | NetGear WGT624 Wireless Router
Asus Router Offline
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Cant send or receive email after hooking up D-link wireless router.
connect ur cable first,from ur laptop to ur router..then if it will function,unplug the cable then connect ur laptop to the router manually..
Apr 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
David Payne
David Payne
