Question about Lands Phones
AL410 duo , second handset has no display and some of the keys not making a beep when pressed. Light on display is on but screen is blank. Any hints could faulty batteries cause these type of issues?
  • 3 Answers
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
SOURCE: screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Posted on Apr 13, 2008
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
SOURCE: Keyboard beeps when any key is pressed
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
Posted on Feb 23, 2009
SOURCE: handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Posted on Apr 30, 2009
My CL80101 will not register, what to do?
1. When the new handset says "Connecting..." and goes
nowhere else, enter *331734 [menu] and it will soon
beep and display "Not registered"
2. To register the new handset to your base: on the base
press the "Handset Locator" button and hold it until the
"in use" light comes on ( ~ 4 seconds ), then release the
button and set the new handset into the base phone
cradle. After ~ 30 seconds it will beep and display
its "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset
in turn: press "Handset Locator" ~ 4sec
( in-use light on ), set handset into the base
cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Apr 21, 2016 | Lands Phones
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
and it will soon beep and display "Not registered"
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
Deregister procedure for at&t el52400 handsets
1. To de-register the orphaned handsets from their old base:
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
enter *331734# (menu)
is still blinking.
Good luck !
Oct 14, 2011 | AT&T TL32100 Cordless Phone
Tring to add a handset to a att 5840 base!
The process is called "Registering."
From another fixya post:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Mar 21, 2011 | AT&T 5840 Cordless Phone
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
Jun 09, 2008 | Uniden Cordless Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
