Question about Cell Phones
I cannot receive incoming texts - Cell Phones
My LGL51AL RECEIVE TEXT BUT I CAN'T SEND TEXT
do you pay for a data plan , if not then perhaps that is why
Jan 08, 2017 | Cell Phones
Can't receive text
If you can send text messages from your phone and just not receive them, it's a problem with your phone carrier and not the phone itself.
Try a quick test and send yourself a text from the web using http://www.afreesms.com. That will tell you if it's a problem with your phone or the other phone you're using to send texts to yourself.
Phone your carrier's support number and tell them you aren't receiving incoming text messages. Chances are it's an issue with your account, or a problem with their network. Either way you will have to get in touch with them.
Dec 06, 2013 | Pantech Cell Phones
Can't receive texts with certain numbers
go to contacts in the phone, go to your entry, press sub menu button, uncheck incoming calls (send calls directly to voicemail)
Jul 08, 2012 | Lg800g With 1200 Minutes And TripMinutes...
My htc freestyle will not receive incoming text messages
I had to got to message and select deleted messages and delete them. If you delete them they are still there until you clear them. I didn't know this.
Dec 07, 2011 | HTC Freestyle Smartphone
I an not able to receive any texts. I am advised that this is because a large text of over 160 characters has blocked all my incoming texts. I have been advised that there is a software fix available...
hi nikrobo,
it is rare that a large text will block your incoming textes, clear all your textes from your inbox, outbox etc, if you can call your network provider, and as them to send you an update text so that you can send and receive textesan update text will clear any memory from your textes. Some networks will be able to update it for you over the phone .. hope this helps mate
Feb 26, 2011 | Cell Phones
I am unable to send texts
you may have to check your settings on the nokia- may not have text message 'up-loading'- 'sending' set up. your service may allow 'free' incoming- but not sending!
check your phone settings- may need to go on-line to alter your settings! or find info to set your phone!
good luck!
Oct 19, 2009 | Nokia N95 Cellular Phone
No voice received on incoming calls
try useing it on speaker phone..if it works there then the problem is in the speaker..it is eeasaly replaced also you can try and do a software upgrade..
Oct 07, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Phone will not receive incoming calls but does receive incoming text. When phone is called goes straight the the answering sevice
the simple solution is just for you to reset the settings or to reset the factory setting. the phone will work properly. Niksnikoko.
Sep 04, 2009 | LG KG800 Cellular Phone
Motorola razr v3. not receiving incoming texts
this is somethng you will need to contact your cell provider about they re the ones to fix this
Mar 30, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
