Question about Garden
Toro 418 zr snow blower was smoking prior to last use. Doesn't start now.
  • Garden Master
  • 2,474 Answers
Was it blue or black smoke? Did you change the oil and overfill it? Is the choke stuck on? Blue smoke is oil burning and black is too much gasoline. Did you tip it over? If you tip it it will make oil go into the valves and pistons.Pull your spark plug and see what it looks like May need replacing as well. Is your air filter clean? All these could effect how it starts and runs.
Posted on Dec 24, 2016
Snowblower won't start
"Gone thru Carburetor" Did you check the Needle valve Seat? The ethanol gas ruins the seat if they are made of rubber and the needle valve is all metal.
Does the Float actually move up and down as it's supposed to? sometimes the ethanol gas absorbs too much moisture and the needle valve or pivot point of the float rusts.
Mar 01, 2015 | Toro Power Clear 418 ZR - Single Stage...
Will not start.but backfires..why?
Clean the spark plug, it might be dirty causing misfire.
Timing might be off, take to repair shop for this.
Feb 13, 2015 | Toro Power Clear 418 ZE - Single Stage...
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Recoil starter
Go to you tube On the line repair recoil core
Feb 14, 2014 | Toro Power Clear 418 ZR - Single Stage...
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
