Question about Garden
Acres in square or radius area would be better
I have 16000 bbls of oil an acre foot is 7756 so I have 2.1 acre I believe and if my height is 2.3 feet vertical what is my radius or square in acres or feet???
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
112.54 ft radius (2.3 ft high)
Posted on Dec 22, 2016
    Top Expert:
  • Garden Master
  • 50,073 Answers
Difficult to know exactly what you are asking here
what is 16000 bbls--abbreviations do not known around the world so you need to be specific
next you are asking for a radius but include a height measurement.
an acre is a surface measurement but as soon as you give a 3rd dimension ( your height) it becomes a volume measurement or cubic ft/ yards or gallons
so post it all again and explain the end result that you want people to answer
Posted on Dec 21, 2016
  • 63 Answers
SOURCE: oil leaking way to much
It is a leaking valve cover gasket (easy fix) or the gasket between the head and crankcase ( most likely but much harder to replace). Check the valve cover gasket first.
Posted on Mar 16, 2009
  • 146 Answers
SOURCE: John Deere 0-turn serpentine belt keeps coming off.
Make sure the belt is under good tension -- shouldn't be able to deflect the belt more than 1/2 inch or so with firm thumb pressure. The belt could be worn and stretched, if so, replace. With the belt off check every spindle and pulley to see that they turn freely. Check that idler pulleys are level to deck and not wobbly -- a sign of worn bushings that cause them to tilt, and that would throw the belt off. The bushings are inexpensive to replace. Good luck!
Posted on Jun 12, 2010
  • 13 Answers
SOURCE: Do you recomend this equipment for 5 acres area?
Possibly, if it does have a a Kohler engine. Avoid A B&S engine. They simply would not hold up well to the heat and wear of that much acreage. I would recommend a John Deere, but, they are not cheap however parts are easily accessible, you can buy a cd with all repair info and their repairs are certified. I have gone through 2 brands of mowers with B&S engines, they literally threw rods and I only mow 1.3 acres.
Posted on Feb 24, 2011
  • 8 Answers
SOURCE: Have a 1370 Case tractor,
Clutch is maybe shot. Maybe low on tranny fluid. Make sure brakes aren't locked on. Wiggle the shifter levers as it maynot be engaging. This tractor if I am correct is an old tractor. Case tractors of this era never were very dependable as far as I am concerned. It might be the reason the tractor was sold in the first place. Hope it helps
Posted on Apr 09, 2011
  • 2342 Answers
SOURCE: I need the formula for figuring square feet, say a 12 x 25 foot square---Need to know how much paint would be needed?
12 x 25= 300 sq ft.
Divide that by whatever the paint can says the coverage is.
if paint says 1 gallon covers 200 sq ft then u need 1.5 gallons
Posted on Apr 03, 2015
Measurement of an acre against hectar
Hectare is a metric surface area measure of 100 metres by 100 metres.
An acre is defined as "the area of 1 chain by 1 furlong (66 by 660 feet), which is exactly equal to 1?640 of a square mile, 43,560 square feet, approximately 4,047 m2, or about 40% of a hectare." wikipedia.org
To convert acres to hectares, multiply the acres by 2.4711.
Good luck,
Paul
Hectares to Acres conversion
Oct 23, 2017 | Office Equipment & Supplies
I just need to know the four side dementions of a 1/2 acrelot the top and the bottom and both side demenstions .not the high or depth of the land just a flat peice of ground
An acre is 43,560 square feet, so a half acre is 21,780 square feet. If the lot is rectangular, you multiply the length of the long side (in feet) times the length of the short side (in feet). For instance if the lot is 200 feet x 110 feet, the area is 22,000 square feet, just a little over a half acre. If the lot is not rectangular, then you need to have a good knowledge of geometry to calculate the area.
Jun 04, 2017 | Cars & Trucks
How many linear feet would be needed to surround a rectangle of a 63.50 acre site?
That depends on the shape.
63.5 acres is about 2,766,071 square feet.
For a square parcel, about 1663 feet on a side, you would need about 6653 feet.
If the parcel is 2,766,071 feet by 1 foot, you would need about 5,532,144 feet.
Oct 18, 2016 | Miscellaneous
I have 4 acres front and back is 650 feet wide so hhow ow many feet deep will make the 4 acres.
There are 640 acres in a section.
A section is one mile by one mile
A mile is 5,280 feet
A square mile contains 5.280 X 5,520 = 27,878400 sq ft.
divide by 640 = 43,560 square feet per acre
multiply by 4 acres = 174,240 sq ft
divide by width 650ft = 268.06 feet
Ta Da!
Feb 12, 2016 | Office Equipment & Supplies
What would the dimensions of an acre be in feet if all sides were equal?
Hi
A square-shaped acre would then be about 208.7 by 208.7 feet (because 208.7 x 208.7 = ~43,560, which is the defined area of an acre.)
Hope this helps.
-Steve
How big is an acre
May 21, 2015 | Office Equipment & Supplies
What is the radius of a 3/4 acre circle (in feet)
Oh wow, lots of math going on here...
There are 4840 square yards in an acre and 9 square feet in a square yard (4840 x 9 = 43,560).
An acre is an old timers measurement used in agriculture...
it was 4 poles wide and 40 poles long. A pole is equivalent to sixteen and a half feet. So back then, an acre was a piece of farming land 660 feet long (220 yards or one eighth of a mile) and 66 feet wide (22 yards or one eightieth of a mile).
Acre is a measure of area, which would be square feet.
Feet are a measure of distance.
The best you could do is something like this:
An acre is 43, 560 square feet.
Draw/imagine a square or a rectangle that would cover that much area.
If it is a square, it would be (approximately) 208.7 feet on each side.
Its perimeter (the distance around it if you walk an imaginary fence around you acre-sized plot) would be 834.8 feet.
Trying to to figure out an acre of 'Circle' - hmmmmm???
Radius = 1/2 of Diameter
sorry, just can't wrap my head around this to come up with the correct equation.
maybe we can get lucky with some other brainiac taking what I did provide and come up with a solution for you?
Square - It would be 208.7 feet across if you walk across it, and the same if you walk the other way across it.
Apr 11, 2015 | PetSafe Wireless Fence System For Dogs &...
If it is 9,329 sq feet how big is it? 1/2 1/4 of an acre?
A SECTION is one mile square.
Each section has 640 acres.
1 mile is 5,280 feet, so a section contains 27,878,400 square feet.
Divide that by 640 acres, and
1 acre contains 43,560 square feet.
Your plot of 9,329 sq feet contains .214 acres, or just over 1/5 of an acre.
Mar 06, 2015 | Garden
Length and width of an acre
An acre is about 4047 square meters or about 43,560 square feet.
A plot of land one meter by 4047 meters is an acre. A plot of land one foot by 43,560 feet (8 1/4 miles) is also an acre.
A square plot of land about 63.6 meters or 208.7 feet on a side is also an acre.
Mar 14, 2014 | GPS
What are the lenth and width dimensions of an acre
One acre is about 43,560 square feet. It could be one foot by 43,560 feet, 2 feet by 21,780 feet, 3 feet by 14,520 feet, etc, all the way to about 209 feet by 209 feet.
Mar 14, 2014 | GPS
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Calculated Industries Pocket Real Estate...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
