Question about Canon Office Equipment & Supplies
Canon copy 2202 fixing unit paper jam problem
Its not working properly
    Habit-Forming:
    New Friend:
  • 25 Answers
It would be much better if you provide some more details and/or images or video of the problem occuring.
Did u tried havier or lighter papers if the problem persists? Otherwise only possible "help" is the suggestion to replace the fixing unit.
Posted on Dec 29, 2016
SOURCE: Paper will not feed properly/one side of paper not feeding in straight
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 23, 2008
  • 42 Answers
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Posted on Nov 21, 2008
  • 990 Answers
SOURCE: canon imageRunner 3200n paper jam in the fixing unit
Hello sir;pull out fixing unit check out the paper sensor that located at the paper exit side,let it move freely.
Posted on Jan 10, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
Canon copy 2202 fixing unit paper jam allways
Your rollers are dirty or worn. Clean or replace.
Dec 21, 2016 | Canon Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Everytime I try to copy something it comes up saying 'the paper is jammed' yet there is no paper jam, how can I sort this?
Hi, you could try switching the unit off then switch on again and let it reboot. If this dosen't fix it their must be a sensor not working properly or a small piece of paper in the workings. If all else fails call the the repair man.
Nov 26, 2015 | Canon imageRUNNER 2520 Laser Multifunction...
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Hey I have installed a duplex unit in my canon iR2018 it was copying normally before I install it and now it is having paper jam after installing the duplex unit
did you properly conect the all connectors?
See instalation manual.
Maybe the duplex unit didnt set very well.
Where paper jam occurs?
Try to clean all rollers on duplex, maybe the unit were very long time stored badly.
Pls. give more info!
Jun 14, 2010 | Canon iR 2016i Black and White Copier
Paper jam in canon Imageclass D861 copy machine
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
May 09, 2008 | Canon imageRUNNER 5570 Copier
378 people viewed this question
old marine
old marine
