Question about Canon Office Equipment & Supplies
Canon copy 2202 fixing unit paper jam allways
  • 575 Answers
Your rollers are dirty or worn. Clean or replace.
Posted on Dec 21, 2016
Canon copy 2202 fixing unit paper jam problem
It would be much better if you provide some more details and/or images or video of the problem occuring.
Did u tried havier or lighter papers if the problem persists? Otherwise only possible "help" is the suggestion to replace the fixing unit.
Dec 21, 2016 | Canon Office Equipment & Supplies
What's your question? how can i resolve canon 2202 photo copy machine display e000 error
Hi. that error indicates there is a problem with the fixing unit. try to clear from service mode. if problem persist . replace fixing heater .
Mar 17, 2016 | Canon Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
Mar 15, 2015 | Canon Office Equipment & Supplies
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
My Canon MF6540 is only pulling paper about 3/4 of way through when I am trying to scan/copy. There is no paper jam, and I have cleaned the machine. What could be wrong?
Does machine eports some eror like paper jam or similar o e001, ...
Check the paper sensor flapper on fixing unit, or clean all rollers with alcohol or water
Jan 29, 2010 | Canon ImageClass MF6540 Copier
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
May 09, 2008 | Canon imageRUNNER 5570 Copier
90 people viewed this question
old marine
old marine
