Question about Canon Office Equipment & Supplies
Canon copy 2202 always paper jam fixing unit - Canon Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
abdu_no635
SOURCE: Canon MX300 Paper Jam alarm
hi I'm 30 eyars old from sudanes girl ilove sexy girl&woman
Posted on May 31, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 393 Answers
SOURCE: lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
  • 309 Answers
SOURCE: Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Posted on Jan 07, 2010
Canon copy 2202 fixing unit paper jam problem
It would be much better if you provide some more details and/or images or video of the problem occuring.
Did u tried havier or lighter papers if the problem persists? Otherwise only possible "help" is the suggestion to replace the fixing unit.
Dec 21, 2016 | Canon Office Equipment & Supplies
Canon copy 2202 fixing unit paper jam allways
Your rollers are dirty or worn. Clean or replace.
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam at fixing unit when copying page with black border and complete tx fax function the tx report will comes out
Does the black go all the way to the very edge.ALL copiers have a void area around the edges of the copy....to prevent the copy from sticking to the fuser roller, which operates at nearly 400 degrees while copying.The void area can be as much as 6 mm all the way around, that is to say, all 4 edges.without the void area, the copy will always jam at the fuser or fixing unit.Good Luck
Mar 26, 2009 | Canon imageRUNNER 400S Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Re: Paper Jam
I'am sorry to say that you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call. You may think about replacing it, sorry for the bad news. I've worked on about 5 of those machines with the same problem and it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
Nov 16, 2007 | Canon imageCLASS D761 Copier
114 people viewed this question
old marine
old marine
