Question about Husqvarna Garden
I have a husqvarna 125B. It starts but runs out of fuel. It will keep running if I use the primer bulb. I put a new carb on it but it didnt help.I used new fuel line also. I dont know what else to do.
  • 22 Answers
Impulse from crankcase drive fuel pump portion of carb. Make sure hole is not blocked. Remove carb and put dab of grease on it and pull rope. It should push grease out.
Posted on Dec 28, 2016
  • Husqvarna Master
  • 10,045 Answers
Sounds like a fuel filter.
Posted on Dec 21, 2016
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Check that the air filter on carburetor is correctly fitted and that the filter element is not blocked. If the filter does not allow air flow it will affect or prevent engine running and by applying the choke the engine will run but it will be using excessive amounts of fuel.
Aug 27, 2014 | Garden
Primer bulb will not prime
Sounds like it could be a number of faults.
1. Crack in the primer bubble its self, not allowing the creation of pressure or vaccum.
2. The plastic primer base has a valve in it. That could either be blocked or damaged.
3. Blocked up fuel line (not very likely)
4. Hole in the fuel line which is sllowing it to suck air up and not fuel.
I\'d be putting my money on 1 or 2.
Jul 03, 2013 | Husqvarna Garden
Chainsaw wont stay running
Get a carb. rebuild kit.
Nov 29, 2012 | Husqvarna Garden
Husqvarna 125B will start and run but once it heats up it stalls and will not start until it cools down
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
Aug 25, 2012 | Husqvarna Garden
What are the steps to start my husqvarna 125b handheld gas blower
Put fresh gas/oil mix (if it is a 2 cycle) in the tank.
Put the choke on. Push the primer bulb 3-6 times. Pull the cord until the engine sputters. Put the chock to 1/2 way, pull cord again. Should start and run a bit with choke set there, then in about 10 seconds, put the choke completely off.
Aug 09, 2010 | Husqvarna Garden
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Nov 22, 2009 | Husqvarna Garden
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Garden Logo
101 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
