Cannot set up onto free view arial works on other TVs but our new tv no connection keeps coming up. Is the set at fault
  • 3,497 Answers
Free View is done via broadband internet !
You need an ethernet connection
https://tenplay.com.au/faqs/freeviewplus
Posted on Dec 21, 2016
Why am I being told that my signal to my tv is weak and that must come to you for assistance.
Are you on cable or Arial If on Arial you may have to turn the head one way or the other to get the program to come in also weather conditions have a lot to do with this.Weather effects the cable reception as well. If the TV works most of the time but not other times it could be the weather. or a weak booster on your areal
Sep 22, 2014 | T-View Car Audio & Video
Power light keep blanking green when then go to stand by and tv won't come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 11, 2014 | Televison & Video
Philips 37pfl5332d won't turn on. A blue light comes on and then turns red and blinks 6 times. Can I fix the tv or is it time to buy a new one?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinks counts to Philips Brand TVs are not direct' like other brand TVs. The details about how to count the fault blinks to Philips TV models are given in detail.
Mar 30, 2014 | Philips 37PFL5332D 37 in. LCD Television
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
I have a hitachi 46f500 projection tv will not work on my new dital antenna
can you explain please. also check the aerial cable use a meter and check that the Arial is wired in right . as sometime it will be down to the Arial than the tv. even a thin peace of the coax cable may be touching the live in the Arial this will make you not get a signal. if the tv was fine before then i would say the arial wire is the fault.
Jan 02, 2014 | Toshiba 52HM95 52" HDTV Projection...
50" plasma tv has a single vertical line in the center of the tv and powers off immediately after the picture comes on
Sounds like COF connection fault. If you wish to get more details, check the site linked here. Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window. It has screen shots of faulty Plasma display. You can see them, and can determine by comparing them to that of your TVs'. http://electronicshelponline.blogspot.com/
Aug 11, 2013 | Samsung 50 in. Plasma TV
Regza 37av504d problems with arial connections
replace the connector of your aerial antenna the problem will be solve
Apr 07, 2012 | Televison & Video
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
