My 65 inch smatr tv is not working.wen i turn it on it says on screen...service is not running? Can u help
4 Suggested Answers
demonicsaint
  • 160 Answers
SOURCE: WS-65513 65 in. Rear Projection HDTV Television: My 65 inch Mitsubishi tv turns off a couple of sec...
The power supply will need to be replaced.
Posted on May 07, 2010
sirgmao
SOURCE: My 65 inch flat screen
This is an easy fix, just change the DLP chip.
I bought one on Friday and it got here yesterday, I followed the video instruction on Utube. I spent maybe 1 hr, because I kept going back and forth from the tv to my PC to watch the video.
The chip is soooo easy to replace, and only cost about 150 bucks at shopJimmy.com
http://www.youtube.com/watch?v=eWRE_k62Ylg
http://www.youtube.com/watch?v=erHUzDulS4c
http://www.youtube.com/watch?v=MZfIJ_PBUaQ
Posted on Jun 20, 2012
SD Tech
  • 14553 Answers
SOURCE: the timer light keep flashing , tv won't turn on ws-65511 65 inch
Green light should blink if set unplugged for 70 seconds and go out:
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different s so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on Nov 03, 2012
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
I connected my 65 inch panasonic viera tv to my laptop but get a black tv screen, help?
If you are conected VGA cable set your TV to PC input. When you turn your laptop press fn then
f8 that should transfer the signal to the LCD.
Thank you
Dec 12, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
May 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
My sony 65 inch projection does not work
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 26, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
