Question about Nakamichi Televison & Video
Nakamichi 300 watt sound bar that will not play sound for blu ray player but does for cable. Both components are HDMI into tv. But sound bar is aux into cable box. How do I get blu ray sound?
  • Kristine Phinney
    Kristine Phinney Dec 22, 2016
    Thank you. But my husband tried your suggestions and they didn't work. The only sound we can get through the sound bar is cable. He even tried the audio outs on just the tv. We had no sound at all that way.
  • Lawrence Oravetz Dec 22, 2016
    When you use the audio outs on the TV you MUST go into the audio setup and select which output ports you want the TV sound directed to
  • Nakamichi Master
  • 10,263 Answers
Look on the TV to see if there is a digital out or an optical out. Might be covered so look closely for it. If you find either audio outs on the TV, then use the appropriate cable to connect to the sound bar.
Posted on Dec 21, 2016
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
How do I hook up my blu ray to my floor model panasonic tv
You can use an HDMI cable if both your tv and Blu-ray player have that imput. That will give you the best picture and sound. Both video and audio are carried through the one cable. Next down in quality are Component cables. You may need to use these if your tv doesn't have an HDMI input. These 3 cables are red, blue and green. They will give you the picture but no sound. This is normal . All component cables need red and white composite cables for audio. When you have made your choice of HDMI or Component, click the input button on your tv remote and scroll down to either HDMI 2 or 3 or 4(if you used an HDMI cable) or choose "component" to allow the signal to come through. Make sure you at least have the blue-ray player on so that when you do see it on the screen, you'll know which input you chose to get it to come through. Remember, after watching your Blu-ray, remember to turn your input back to your cable setting so you can watch tv again
Dave
Jan 28, 2015 | Panasonic Televison & Video
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Jan 01, 2015 | Sanyo Televison & Video
My blue ray / dvd player surround sound won't stay on when I have it on AUX for the TV. Model # SA-BTT195 (?)
What do you have plugged into the AUX port?
Have you tried HDMI 2 some tvs have a smart link on HDMI 1 that auto wakes the component connected to it but I dont know your situation.
Sep 20, 2014 | Panasonic Televison & Video
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Cannot get it to play using hdmi connection to my vizio HDTV -- works with component cable but not hdmi. Have tried three hdmi cables to no avail
U tries all the HDMI ports on the tv,might have a short and dead the one HDMI port,u tries,with all of those three HDMI cables.
Nov 18, 2010 | Panasonic DMP-BD35 Blu-Ray Player
My panasonic blu ray wont play space odyssey 2001 the tv says mode not supported, it plays the sound but no picture all other blu ray discs play as normal. Can you help?
I did solve the puzzle what I did was to, disconnect the HDMI cable and reconnected via component video and it worked well. I am still not sure why it wouldn't play with HDMI as all my other blu ray discs played OK.The TV is a Samsung 52in lcd.
Oct 27, 2009 | Panasonic DMP-BD30K Blu-Ray Player
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
redthroat@hotmail.com
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
24 people viewed this question
Top Nakamichi Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Lawrence Oravetz
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
