Question about Ricoh Office Equipment & Supplies
How can i fix the error code 829 in ricoh copier 4500 that error comes after i moved the machine during that the two lower drawer block drop down .then the error code comes when i switc it on.
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
The fusing lamp stays on at full power for 70.0 seconds while in the stand-by condition after warm-up is completed.
Possible Causes
fusing thermistor defective or dirty
Clean or change.
shut on the copier, press clear modes(yellow button), 107, and then hold down clear/stop (orange button). Enter 5810 then # key then 1 #. Turn off the main power then power back on to clear the SC condition.
If it does not solve it, the problem can be in board AC drive PCB2.
Posted on Sep 15, 2009
SOURCE: I have error code sc329 on my Aficio/ricoh copier.
In some models this code means that the laser has aged and must be replaced.
But he would be interesting to know that model is for being safe of this.
Posted on Sep 17, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
  • 183 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
As i power on my ricoh mp2000le this is the error i saw. sc 829 code 301 detail ac000000. whats the meaning and solution?
here are some reasons.
1.Self-diagnostic Error: Optional RAM
The optional RAM returned an error during the self-diagnostic test
Resolution - ( Replace the optional memory board
- Controller board defective.
2.Charge roller current leak
The polling module detects a current leak of the charge roller. Causes as follows' • Defective charge roller
• Defective high voltage supply board
• Loose connection of the PCU.
Feb 26, 2015 | Ricoh Office Equipment & Supplies
This IS a fatal kernal error, of the controller, the ONLY hope without changing the controller/hard drive, is to power down unplug copier,( I turn power back on with it unplugged) this bleeds off power in the caps. I have had this issue 3 times this year. -Carl
Apr 27, 2014 | Ricoh Aficio 450 Copier
SC:829 code:0301 detail:0xA4000004
ram ,printer broad or hard disk board will have some problem try replacing after cross cheking
May 05, 2012 | Ricoh Aficio 2022 Black and White Copier
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
What is error code sc542
I found some information on this error at
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
I have an E-405 error code on a Ricoh FT5832 copier. Is this something I can fix?
Transfer belt error...the symptom is usually several "clicks" during cycling just before the machine warms up. It is the clutch that needs replacing. Sorry, you need a technician for this.
Mar 12, 2009 | Ricoh FT5832 Copier
Paper drawer won't open all the way and it won't copy
1. Turn the system off
2. Go to the right side of the unit and open the side panel will drop down
3. Move to the front of the machines and pull the drawer out as far as it will go, if it stops that meant there is a piece of paper caught in the take up area.
4. Go back to the side where you opened the panel and look for the lead edge of the paper, if you see it grab hold and up and towards you.
5. If you can't see the lead edge of the paper you will have to force the paper drawer out, just pull hard and the drawer and a piece of paper will come out.
6. Remove the drawer completly and then look in the paper drawer cavity for the remaining piece of paper.
Dec 28, 2008 | Ricoh Aficio MP1600SPF Copier
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
