Question about Winter Sports
93 Polaris xlt, what should the exhaust temperature be for each cylinder
3 Suggested Answers
  • 46 Answers
SOURCE: I have a 98 polaris
THIS ENGINE IS A PORT ENGINE, ANY TWO STROKE OIL WILL WORK. HOWEVER EVERYBODY HAS DIIFERENT OPINIONS ABOUT WICH OIL TO USE
Posted on Jan 07, 2011
claudeinmo
  • 9098 Answers
SOURCE: 93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Posted on Jan 04, 2016
May 8, 2013
Feb 13, 2012
Dead cylinder
Dec 11, 2011
Feb 22, 2011
Jan 04, 2016 | Cars & Trucks
I have a xlt 580
I would check/drain the carb float bowl first, let it drain into a container then look for any water/contaminates. Second I would remove the carb, then remove the float bowl and do some serious inspections/cleaning . Also a faulty spark plug will cause some conditions as described. A dirty/clogged air filter can cause similar issues. As the unit runs look at the exhaust stream exiting the tail pipe and check for black or blue smoke. These can determine certain operating conditions which can help isolate the problem as well.
Dec 19, 2011 | Polaris ATV
My pull cord on my polaris ind xlt broke can i put it back on
YOU WILL HAVE TO REMOVE YOUR RECOIL TO PUT A NEW PULL CORD IN. THIS IS DONE BY REMOVING THE EXHAUST THAN REMOVE YOUR RECOIL ASSEMBLY. BE SURE TO WIND THE RECOIL BEFORE INSTALLING YOUR NEW PULL GORD.
Dec 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Got a used polaris xlt that has"ran in 6 years got it running but it doggs out at half throtle what can i do?
that sounds like a coil is gone bad and you are running on 2 cylinders, that or the carbs are being starved or flooded, many posibilities
Nov 29, 2009 | Polaris New Genuine Polaris Snowmobile...
93 polaris xlt tripple wont run to full potential
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Feb 10, 2009 | APW Wyott Sport & Outdoor - Others
Winter Sports Logo
97 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
